Disconnections for at least a week
- Re: Disconnections for at least a week
26-08-2018 11:24 PM
@ PN Support Team
For more than week I have experienced broadband disconnections every couple of days.
Today, it was really bad. The landline had a dial tone, but the broadband was disconnected for nearly 4 hours.
Is there any work carried out by Openreach in my area? If so, why was I not informed of this?
All this on top of BT Wholesale Speed test still not working for me - using IE11 with W10.
Your input on both above 2 issues will be appreciated.
Chandu.
27-08-2018 11:59 AM
Sorry to hear you're having issues.
Our tests aren't showing any cause for this and there's been no outages reported in your area.
If the drops continued I'd recommend raising a fault here so we can investigate further.
28-08-2018 8:04 PM
I have gone through these tests before with Adam Walker some years ago, when he had decided to do the "lift and shift" of line and since then I have had very stable line. All of a sudden lately, I am having unstable line (every couple of days). So, it makes me wonder if BT Engineer/s has/have put me on an unstable line, accidentally or otherwise.
Chandu.
29-08-2018 9:14 AM
Hi Chandu, your line isn't likely to change unless we've placed an order to do that (which we haven't) or if a fault has been investigated. As some time has passed it would be a good idea to do the checks again as line conditions and other environmental factors are likely to have changed. Let us know how you get on.
29-08-2018 7:14 PM
@adamwalker and @MatthewWheeler,
Hello Adam, long time since I had a post from you!!!
As my connection has been stable for over 2 days currently, I will wait and see how it behaves in next few days and then decide to go through the tests suggested by Matthew, if necessary.
Currently my noise margins are: 6.2/5.8 upload and download respectively
So, let us see how it behaves and what noise margins causes it to drop the connection.
Many regards,
Chandu.
29-08-2018 7:27 PM
Hi @chandu,
That would be brilliant, thank you - please let us know if this issue returns and, if so, whether the troubleshooting checks have helped.
01-09-2018 1:42 PM
Thanks for your prompt response.
The connection has been stable for over 5 days. I have made no changes at my end. So, it makes me think that something had been happening in my area either at the exchange or at the cabinet during the week in question.
Chandu.
01-09-2018 6:44 PM
11-09-2018 7:40 PM
Hi Guys,
Just to let you know that I have had a stable connection for just over 15 days. It disconnected briefly yesterday, 10/09/2018 and reconnected soon after. It has been stable for over a day with noise margins of 6.0 dB (upload) and 6.1 dB(download).
Let us hope that with these noise margins it last for just as long.
Regards,
Chandu.
12-09-2018 10:52 AM
12-09-2018 8:02 PM
Hi @adamwalker,
Yes, it is great news. But what worries me is that some 3 weeks ago I have had multiple disconnections within 1 week and yet your records shows that every thing was good. I suspect something was going on at BTW in my area during that week (either at cabinet level or in exchange).
Currently we are connected for over 2 days and my the noise margins show 5.9 db (up) and 5.7 db (down).
No doubt, if it does start to misbehave, you will hear from me.
Regards,
Chandu.
