Disconnections and slow speed
- Disconnections and slow speed
Re: Disconnections and slow speed
16-07-2014 5:19 PM
16-07-2014 5:27 PM
16-07-2014 5:31 PM
If you can come back with confirmation on those last few post queries, then I'll suggest what to do next.
16-07-2014 5:39 PM
16-07-2014 5:41 PM
16-07-2014 6:22 PM
Can't remember on the v4, when you log into it have you obviously have the Show Statistics, if you could post the full stats from that before shutting down but do you have the Connection Status one, where it will show Connection Time, IP address, and etc with Connect and Disconnect buttons at the bottom if you have.
If so, after you post the Show Statistics info, go to the Connection Status and click Disconnect. Wiat about a minute and then pull the 834 power plug. Also close Routerstats.
Wait about another minute and then unplug from the line. If you think one of your other filters may be a better qualirty, swap over, remembering what I said about the plug in and out a few times to help clean contacts of any oxidation. Whilst you are about it, if you haven't already checked make sure the incoming BT cable connections on the backof the NTE5 are secure, not corroded etc. Were they screw terminals or IDC?
Anyway, all in all stay off-line for about 10 minutes minimum, it won't matter if you take a bit longer.
After that connect up again and power up. You may need to login to the 834 if you clicked Disconnect before going off and click on Connect on the Connection Status page as it may not reconnect automatically.
Restart Routerstats and also post the full Show Statistics info.
In the meanwhile I'll draft a couiple more additions to RS settings that may yield some further useful data.
16-07-2014 6:52 PM
ADSL Link Downstream Upstream
Connection Speed 4698 kbps 928 kbps
Line Attenuation 42.5 db 21.0 db
Noise Margin 17.0 db 6.9 db
I'll follow your shutdown routine and will clean all connection in filter, router and PC. The line coming in goes to screw terminals and they looked okay and weren't corroded. I checked these the other day when either you or Kevin (or maybe Chris) asked me to check the type of cable and wire colouring of the incoming line. I'll post back with the new stats once all that is done. Wish me luck, I may be gone some time...
16-07-2014 7:00 PM
16-07-2014 7:25 PM
Connection Speed 7645 kbps 1119 kbps
Noise Margin 6.3 db 5.7 db
Routerstats looks odd though. Overlayed rx sync speed on the graph is showing about 12.8 and not 7.645 EDIT: Sorry, I was reading the dB scale, need a break from this I think. tx graph is still showing 0dB instead of about 5.8dB that router says. I did close down and restart routerstats for this procedure.
Barry.
16-07-2014 8:04 PM
Before we try anything else then, all I can think of is stop Routerstats. Go on the Configuration tab and go through each page and check the settings are correct as per Kevin's post #78 EXCEPT the login address is not Telnet and it's preselected for you. Also ignore the Bitloading stuff, the setup is different for the 834v4 and I'll come back to that.
16-07-2014 8:34 PM
Many thanks,
Barry.
16-07-2014 9:00 PM
If so, try the following and we'll see if we can get the bit loading stuff.
I'd click on the Stop before making the changes.
Back to the RS Configuration & once open on the RHS you'll see the tab marked Telnet, select that.
Now there are 2 tabs, Netgear settings and Experimental settings.
On the Netgear settings, select Enable Telnet. The next box, Automatically disable router debug is probably pre-ticked, if not tick it.
Select the Netgear version 4 in the next box, and below select Errors during the latest 15 minutes. On the RHS tick remember Y-axis limits.
Click Apply & Save.
On the Experimental tab, the Enable telnet with the http 'debug' command should be ticked. The boxes below should be pre-filled and the Chipset should be Broadcom.
On the RHS tick Obtain Statusbar WAN Uptime from telnet, tick Disconnect when Stop button is pressed and Retry if timeout. Mode Auto should be selected. Click Apply & Save and then close the Configuration window.
Back on the main Tabs, select Telnet Router, then >Bits/Tone tab, then >Options tab
The select Refresh every 10 seconds, tick the box below 'Don't refresh ....when minimised...", tick Show Vertical grid lines,. select Ramp.
Clip SNR values 20 & 0. On the RHS, X-axis 250 Y-axis 10, tick adjust y-axis automatically.
Now goto the "Bits & SNR / Tone" tab on the same row on the left hand end and tick the box in the bottom left of the graph to plot, also Auto Refresh below that.
OK go back to the normal Noise Margin tab, then click the green arrow above and check it's plotting OK then go back to the "Bits & SNR / Tone" and hopefully that will have plotted the Bits/Tone. If so, right click, Capture now and then post a copy.
16-07-2014 9:19 PM
16-07-2014 10:13 PM
16-07-2014 10:26 PM
