Disconnections and slow speed
Fixes: 160
Re: Disconnections and slow speed
Hi Barry,
Good to see that Anotherone (who taught me a lot of what I know in respect of ADSL) is looking after you whilst I'm away.  On ferry crossing at the moment so good Internet access and I've had to deal with an issue with one of my referrals who is travelling with me.  No rest for the wicked.
Some pointers from me...
1. The omg event - as Anotherone suggested, the resynch occurred whilst the interference was still present - you can see the 6dB plots on the up edge of the depressed synch speed plot.  Pretty dammed quick thereafter the noise went away with the consequence of a 17dB SNRM.  I would have resynch'd at that point rather than change the RouterStats pilot axis values.
2. Tone plots - I see you are getting into the depths on RS  Cheesy - can you select the up to tone 512 (IIRC) option - this will allow visibility of the high end tone utilisation(if any).
3. At its best, this line is performing 2Mbps below expectations - I think you have done as much as you can to close the gap.  There is a 1.6% variance between the AE and BE capacitance measurements.  For a well balanced line this should be below 1%...
I believe it is time to call in BTOR to check out the external line - the decay in SNRM rectified by an incoming call is clearly indicative of an external line fault.  Look up Uncle_Meat's long similar saga on picking up the receiver delivering marked improvement of SNRM.  http://community.plus.net/forum/index.php/topic,125789.0.html
Cheers,
Kevin
Anotherone
Champion
Fixes: 21
Hi Kevin,
just a couple of comment on your suggestions  Wink
1) The reason for changing the scale was to see what the SNRM graph was looking like, and silly me has forgotten to ask Barry to post it  Embarrassed
Barry if you could post that last Rx Noise that would have been saved when you shut down for the restart.
2) I don't think we are going to see any tones above 255, the fall-off is too great at that top end, but it may look different with a daytime one, we'll have to see.
3) If you recall, ChrisP did a Cu test and it wasn't showing anything untoward, except you queried the capacitance values, as would have I, but I don't think they are outside BTOR limits  Sad  ChrisP may come back and comment on that. So pursuing something with BTOR would probably be fruitless at this moment. As you well know, intermittent faults are an absolute pain and unless something shows up on a formal test at a given instant, it will just get rejected as NFF. Even if the line is still erroring quite highly, although that may be enough to get a Fault moving with BTw, I'd suspect the most likely outcome would be "raise the Target SNRM" to see if it stabilises - you know what that means. But again we'd need ChrisP to comment.
Also we have to eliminate the filter, which has been swapped, so if the same occurs again, we'll know it's not that.
We'll also then have to do a modem/router swap and leave the other running for a period, to be certain it's not the modem/router causing the problem. I wouldn't really want to see that swapped just yet, as we haven't accumulated enough data either with this one, or since the filter change.
So my recommendation would be steady as she goes for a bit longer.
OK Barry, that Bits/Tone is pretty much along the lines of what I might have expected to see, I've only glanced quickly, I'll study it in more detail later. It's a trifle disappointing at the top end.
Now this Tx Noise not plotting correctly still, also the scale being up the creek, as you've checked the settings, I can only assume that the Routerstats.ini file has got corrupted, which was my earlier thought, and the only cure will probably be to start a fresh one  Sad
That means going to the folder where you have Routerstats installed and, with Routerstats stopped, well you could rename the Routerstats.ini file rather than delete it  - actually attach a copy of it to a post, I'll have a quick look to see if there's an obvious thing I can spot. So then rename it, so when you start Routerstats again it will generate a new file, but you'll have to go through all the settings and enter them all again.
Now as to the cause of this "event", I'm beginning to wonder if it was a power glitch. Atm that's the only thing I can think off that could have caused a corruption to Routerstats.ini and caused the connection to drop and resysnc. Are you prone to power glitches or brown-outs or even cuts on occasions?
The other thing you could do tonight, particularly if you don't want to bother generating a new .ini file tonight (or possibly editing the current one if I spot something) is to go back to the Telnet Router >Bits/Tone >Bitswaps/Tone graph and put a tick in the bottom LH box to get it plotting, and also right click on the graph and select it for scheduled capture.
Hope you see this tonight, that may be useful.
ratbag
Thanks a lot both of you. I won't pretend to understand the technical talk or acronyms, I'm just following your guidance. I've attached what I think is the last plot before the reboot. Just a couple of points:
I haven't changed the filter, it's the same one I've been using all along.
The scale problem was my fault. I was getting the dB and sync speed mixed up.
The tx plotting is still not working so maybe I'll delete the ini and redo the parameters later if we really need those figures
No power problems that I can see. No flashing clocks waiting to be reset. Also, the computer is a laptop and I think the battery should take over.
I have stats from about 10PM last night.
Now, I'm a bit concerned about this 9 year old laptop running 24 hours with the hard drive constantly saving routerstats data.  It's constantly going click click click (they are known to be noisy) and the internal fan is on constantly. Are we able to do these tests without it running 24 hours? Maybe make some changes and then do a couple hour test something like that? Also, I don't want to leave the computer running when no-ones in.
Filters: Does the type or quality of a filter make any difference to the ADSL side of things while the phone isn't being used?
Finally, I've had another disconnection this morning. Speed dropped slightly on reconnection to 7510 from previous 7645. Will post stats if you want them.
Many thanks,
Barry.
Pettitto
Fixes: 5
Hi all,
I've attached some line detail, there's some 'Additional DP information' which I hope you find useful. From what I can see on the line is that it's relatively stable as seen here:
<img src="http://community.plus.net/visualradius/generated/image14055873986666.png"/>
I can't see too many issues on the line quality side of things, if anything it has improved, which is why DLM has put the Line Quality 'Green'. I think if there is a fault with the service, if anything, it's likely to be an issue with the copper jointing, which we can get looked at, however, it'd be as part of a home engineer visit.
I've attached some line information which I hope you find useful.
Anotherone
Champion
Fixes: 21
Thanks for all the data and your comments Chris, very useful. I'll come back to that.
Hi Barry,
I'll answer your queries in reverse order -
The drop this morning was undoubtedly Chris doing the Copper Test, see the time on the second attachment, so not to worry about that.
Yes the quality of the filter is important all the time, to try and explain in very simple non-technical terms, some of the filter components "bridge" the line for filtering of the phone socket. Poor/cheap filter design means this will have the unwanted effect of causing some/even significant attenuation of the Broadband signal.
So later today at some point, if any of your other filters are believed to be either the same or better quality than the one currently on line, then use the disconnect and power down method, clean contacts etc and swap it.
I understand your concerns about running the laptop all the time, switch it off when you are going out, if today (during daylight) do the filter and leave the modem/router off as well. Whilst the modem/router is off, ring your landline from another phone several times and let it ring for a good while.The ringing current will help clean up any iffy joints which may stabilise things for a while.
The only problem with not running RS all the time is that if a problem occurs when it's off, you don't see exactly what happened. If whilst things seem relatively stable then more "random" monitoring may be an idea, I'll come back to this one later today.
Post up a copy of the .ini file and I'll see if I can spot where it's been corrupted, but if in the meantime you have time, rename it and create a new one. The Upstream Noise Margin on an uncapped 21CN line can also provide a picture of line issues that don't always show up on the downstream noise margin.
Posting available SNRM etc graphs is always useful, they may sometimes show something not seen previously or unusual. I'd also be keen to a see a capture of the Bits/Tone graph from now/mid-dayish.
I'll post later about the data from Chris' s tests (have things to go & do) but essentially, as he says, it's looking pretty stable atm.
Good luck with sorting RouterStats and try and do that filter change if you have another good one. I've also got some further ideas if things still look stable.
ratbag
Thanks a lot. I've been out but I'm back for a while so thought  I'd look at what's going on. Think I've sorted the plotting problem. Renamed the ini and started from scratch using the settings provided on 3 posts. rx noise scale is set to 12 again, tx scale is at 10. Don't see where that can be changed, suppose it doesn't matter in this case.
Before I shut the system and router down for a couple of hours, change the filter and do the 'ring ring' test, I may as well post the stats for overnight and the bits /tone thingy that you asked for. Sorry it's not midday anymore.
For new stats, I've set the image format to png, hope that's okay. Smaller files for this type of image I think and clearer. Let me know if I should change it back to jpg.
Barry.
ratbag
double post
Anotherone
Champion
Fixes: 21
Hi Barry,
png files will be fine. Bits/tone is OK, I did say "ish" re mid-day.That's fine, I just preferred it not to be late afternoon.
Tx scale is automatic, no way of changing it.
Well done with setting everything up again, if you can post up that old renamed .ini   I'm curious to see how it got corrupted. If you can't readily print it to a pdf, just open it in say notepad, select all and copy, and paste it into a post.
If you can also post the latest stats from the DG834 and any Rx & Tx Noise graphs that you have since the filter change and a current Bits/Tone that would be good.
I'm going to have a detailed look at what you've posted so far. At a first look, there's nothing unusual.
ratbag
Thanks Anotherone,
Going to have to post stats and ini tomorrow hopefully, got migraine starting, need to get off computer screen otherwise it gets worse and lasts a couple of days. Sorry about that, I'll leave routerstats running anyway.
Barry.
Anotherone
Champion
Fixes: 21
That's fine Barry, don't worry, hope the migraine clears quickly. Leaving RS running tonight would be good.
Anotherone
Champion
Fixes: 21
Hi Barry,
Hope your migraine has gone.
I didn't finish looking at everything last night, we had a lightning storm and lots of errors on my line so I gave up in the end.
I've got to rush at the mo but will look more at things this afternoon.
If you can, post up any stats/graph from this morning as well as those previously mentioned.
I'm hoping that you may have a captured Bits/Tone from last night and if you could do another about "mid-day" ISH Wink
It looks as though your line is picking up a bit of MW/AM interference especially after dark, so it's likely to be down to what the cause of that may be, other than long line,  and what we might be able to suggest to improve things.
Anotherone
Champion
Fixes: 21
Hi Barry,
I guess unfortunately your migraine is still troubling you. Post when you can, no rush.
I have had a good look through everything and there isn't inherently anything obviously wrong with your line. There is in all probability an intermittent issue probably with a joint somewhere, but the difficulty with these things is until it chooses to show itself in a more sustained way, they can be a pain in the bum to find. The best way to proceed is to be as certain as one reasonably can there there isn't an issue with filters, your modem/router, internal wiring etc. We've already tackled the potential issues with the internal wiring and when I see some graphs since you changed the filter, that may give us a better idea about where we stand.
A few things worth noting from Chris's test results.
The mean time between errors both down and upstream has been quite variable, at the moment upstream has dropped compared to previously, in part this will be related to the uncapped upstream change that took place around then, but one would still hope for better figures and better stability on both. The increase in Uptime duration and drop in number of retrains will no doubt be in part due to the ILQ having gone Green.
Whilst Kevin mentioned the capacitance, that difference between each line is not especially helpful, it's way short of a 15% figure that might get Openretch to do something about it, and of course note that the test result at this time was a Pass and atm the line is considered stable!
Two things I note from the DP analysis in the last attachment "Line performing equal to or better than other lines on DP" also "Predicted speed 4500".
Hmm, my comment, that doesn't say an awful lot about the quality of the cable!
The graphs so far have shown that there's random intermittent joint and that the line does pick up some MW/AM interference. There's always the possibility of a small amount of REIN as well, but no real evidence of that.
That's a medium to longer length line so performance is never going to be super good, and I'd guess that there's a fair bit of it that's overhead. Any idea, how much may be?
The only other thing I've noted for now, (from the first attachment) is that the MSR/FTR are stupidly low, in fact unreasonably so. You'll never get a line speed fault looked at with those figures Shocked  So when this is all rapped up, that's something we can ask Chris to try and deal with for you.
From some of the MW/AM radio interference that you are getting, you are obviously in the S. of the country,  bordering on the SE. Anyway when you get the chance to post up some more graphs, we should be able to make some more suggestions that might enable some more convenient monitoring & usage, and getting the best from things as they are.
Fixes: 160
@Anotherone,
I'd read somewhere along my research the suggestion that AE / BE capacitance differences should be less than 1%.  Is that wrong?
What's your take on the deminishing SNRM followed by a synch loss and synch at a slower speed, circa 9am on the last plot from Barry?  Incoming phone call?
I've skim read the thread so I might have missed something - hopefully I'll fall asleep soon on this uncomfortable ferry seat.....
Kevin
ratbag
Right, sorry about that chaps, hopefully back to normal now. Off to bed soon but thought I'd post that ini file and some stats and read your comments. You're right in your assumption that I'm in the South East.
Now,, I haven't actually changed the filter yet. I was going to then saw that I'd neatly stuck it down with double-sided pads when I re-did the wiring and couldn't bring myself to rip it off. It's a cheapy anyway, what I'd rather do is get a decent named one like you suggested to be sure. The thing is, where to get one that's not going to be junk? Any ideas appreciated. There are loads on ebay ranging from a couple of quid to double figures. Most say they are "professional" of course (whatever that means; people who use the internet for a living presumably!).
Now, like you anotherone, we've had storms both early hours yesterday and again tonight. Some of the stats are probably useless but I'll post them anyway as that's all I have. These are from yesterday through to this morning with a gap somewhere around 3AM when I decided to turn the computer off as I didn't want to chance it frying. Then the storms returned a couple of hours later as can be seen. Here are the first 9, not allowed to post any more it says. Will post more after.
ratbag
Here are the others plus the corrupted ini file. I changed the ini extension to pdf so I could upload it but it's still an ini.
I've only quickly read through the latest replies so sorry if I've missed anything you asked, will have a better read tomorrow.
Thanks again,
Barry.
