Disconnections and slow speed
- Re: Disconnections and slow speed
- « Previous
- Next »
12-11-2014 9:39 AM
12-11-2014 9:46 AM
12-11-2014 11:20 AM
12-11-2014 11:23 AM
13-11-2014 10:46 AM
You've had a long litany of issues this year...
Kevin
15-11-2014 10:02 AM
I lost internet connection a while ago, both DSL and internet lights went off on the router. Once the connection re-established, I checked the phone and have a tone again.
Barry.
15-11-2014 10:07 AM
Do you have a confirmed resolution?
Can you please post the current modem stats?
Kevin
15-11-2014 12:34 PM
No confirmation. Hope they will confirm or otherwise.
ADSL Link Downstream Upstream
Connection Speed 7467 kbps 888 kbps
Line Attenuation 42.0 db 20.6 db
Noise Margin 6.1 db 11.2 db
From experience, that dB value will go down later in the day and it will disconnect and reconnect at a slower speed. Which is fine. You've explained why that happens somewhere here.
The internet's been fine throughout this anyway, it's just the phone that wasn't working.
Barry.
15-11-2014 3:40 PM
Is the Quiet Line Test perfect now?
15-11-2014 5:23 PM
Yes, I sorted out the wiring. Internet's been fine for ages, good enough for me anyway.
Chris said the test showed a fault at the exchange side. however, it started working again today and no-one's said that it has been resolved and so I don't know if BT are still coming on Monday or not. If it just started working by itself then that means it will go wrong aging. Hopefully Chris will reads this and let me know the situation.
Barry.
16-11-2014 5:16 PM
The reported line speed is rather low for the line's attenuation, so it could well be the case that there is still a phone fault requiring rectification. IIRC last time around, did the engineer want to replace your drop wire, but you did not have time to spare. (Might have been in one of the other threads I was dealing with at the time.).
Remember if they decide to look at the drop wire connection then you might get them to swap the line to the other socket in the study.
Kevin
16-11-2014 5:51 PM
I decided I didn't want the drop wire changed to the other socket as it would cause me to have to do more re-wiring now for phone extensions and it's not something I want or have time to do for now. Currently my stats are:
Noise Margin 4.9 db 10.7 db
It's working fine for me. The phone still works and is not noticeably noisy. The thing I'd really like to sort out though is whether the line has been fixed due to me reporting it or whether it has just started working by itself. Plusnet haven't told me that it has been fixed and I don't know if I have to wait in tomorrow in case BT to turn up. I'll have to contact them I suppose.
Barry.
- « Previous
- Next »
