Disconnections and Inconclusive Tests
- Disconnections and Inconclusive Tests
- « Previous
- 1
- 2
- Next »
Re: Disconnections and Inconclusive Tests
03-02-2016 1:14 PM
I still haven't completely ruled out that there's something up with my internal setup this time as well as an external problem, but it's hard to tell when I have no control over what's happening on the external side. Last night on the Thomson in the main socket I I lost connection again and couldn't get back, so I left it off for the night. Today I'm on the Asus router on the bedroom socket with a new Maplin filter and it's sort of OK (only one drop in two or three hours), but right now the bedroom phone isn't connected.
08-02-2016 12:48 PM
17-02-2016 11:02 PM
18-02-2016 4:46 PM
(I feel a little bad about making a fuss over the difference between 11 Mbps and 15, which is mostly unnoticeable for practical purposes, when so many people manage with much less. But when I know it's possible, and technology is supposed to get better over time, not worse, it seems a shame to settle for gradually declining performance.)
19-02-2016 11:28 AM
My SNR change also reduced my speed to less than I had previously (with a stable connection prior to the problem) so it's kind of annoying as the SNR change seems to be their solution but to me it's masking the problem rather than solving it. So you are right to make a fuss. They are now going to change my line to interleaved so we'll see what happens.
I still wonder if they are missing something somewhere. Lots of people on here having disconnection problems. They need to spot the pattern. (The problem often seems worse on a Friday. Strange. But I don't think that's the issue)
Anyway all the best of luck.
19-02-2016 4:25 PM
Quote I still wonder if they are missing something somewhere. Lots of people on here having disconnection problems. They need to spot the pattern. (The problem often seems worse on a Friday. Strange. But I don't think that's the issue)
Unfortunately disconnection problems can become more prevalent following spells of wet weather. If the sync is dropping out this indicates an issue somewhere along the line from the exchange>premises causing it. Anything after the exchange isn't going to cause sync drops.
20-02-2016 8:45 AM
I just rebooted the router and it's up for now.
Modulation : ADSL2+
Annex Mode : Annex A/L
Line State : up
Lan Tx : 16125397
Lan Rx : 10000643
ADSL Tx : 2747
ADSL Rx : 4094
CRC Down : 0
CRC Up : 43
FEC Down : 0
FEC Up : 1150
HEC Down : 3494
HEC Up : 0
SNR Up : 4.7
SNR Down : 6.6
Line Attenuation Up : 12.2
Line Attenuation Down : 21.0
Data Rate Up : 804
Data Rate Down : 15349
That 'SNR up' doesn't look right. ...
(Edit: And then it dropped again, synced at 16-something and tried futilely to connect for four hours until I came home and rebooted again. Did the interleaving get taken off again?)
I'm not sure why rebooting the router sometimes helps when the problems still occur with a different one, but it seems like it gets stuck in a loop of trying and failing to connect, and a reboot breaks that cycle and gives me at least a few minutes of connection.
This looks a bit more sensible, but we'll see how long it holds:
Modulation : ADSL2+
Line State : up
Lan Tx : 16207059
Lan Rx : 10046595
ADSL Tx : 1197
ADSL Rx : 1232
CRC Down : 0
CRC Up : 0
FEC Down : 0
FEC Up : 44
HEC Down : 0
HEC Up : 0
SNR Up : 11.7
SNR Down : 7.3
Line Attenuation Up : 11.8
Line Attenuation Down : 20.0
Data Rate Up : 828
25-02-2016 11:11 AM
I don't know what to ask for at this point -- obviously I can't have an engineer move in to watch until the problems start again, but I don't see what else would help. Perhaps just let the DLM find its own level over the next week or two and see what happens? I don't really want to close the ticket when nothing is resolved. I can't complain about Plusnet's service; I just seem to be up against a pesky intermittent fault that's frustrating for all concerned.
26-02-2016 7:26 PM
I had a BTOR engineer visit mine today. It had disconnected two or three times that morning but typically when he was there it was fine. But they only test for 5 minutes. Well I reckon when mines bad it drops a couple or 3 times per hour, so obviously testing for 5 minutes is not enough. But as soon as they find no fault on the line they try to blame your internal wiring or something then they go off on their merry way, instead of actually trying to test external to your property (ie at the exchange or junction box etc) where, in my substantive experience, the fault ALWAYS lies. Or sometimes they blame the ISP (and the ISP blame them!). Argh, makes you tear your hair out sometimes. Strange though, after he left the problem seemed to improve somewhat, like he HAD done something external (?). But it has still dropped a few times over the day so not sure.
Like you I'm just waiting to see over the next week, and hoping they don't close the ticket like they did last time.
27-02-2016 10:37 AM
My engineer seemed quite thorough with the testing inside -- he was here for an hour or so, though the last ten minutes of that were a tea break --- but the line refused to drop or even throw a CRC error while he was looking. I do suspect something external, given what looks like a tendency for problems to crop up when there's been heavy rain or when the pavements between here and the exchange have been disturbed. (But that could be confirmation bias on my part.)
15-03-2016 10:20 AM
At 1.40am the connection dropped, and then it couldn't re-establish a connection to the internet (ADSL light was on, internet light off).until I woke up and rebooted the router. Maintenance work, or the same problem again? Of course my ticket was closed a while ago.
15-03-2016 10:50 AM
YOu can then have proof of your problem and a lot of data that should enable PN & BTOR to diagnose what is going on
https://www.samknows.com/meet-the-whitebox for more details
15-03-2016 11:25 AM
... on the other hand, the internet (but not the sync) just dropped briefly again, and 9000 CRC errors in three hours doesn't look good. I was getting a few a day over the last couple of weeks.
- « Previous
- 1
- 2
- Next »
