Disconnections Low SNR at Evening
- Disconnections Low SNR at Evening
Re: Disconnections Low SNR at Evening
19-03-2014 12:36 PM
Well it looks like what ever he done yesterday has increased the Line Attenuation for no reason what so ever
1. The interference/problem is still on and looks like it will be on for one of it's 4 days stints that it does, so can you sort out for BT to do a lift and shift as this is the only way I can see at the minute to help eliminate/fix the problem.
2. I don't like the way the BT engineer had to come in to do his tests when he had the notes and was told not to and just raise a rein case instead
3. I don't like the way that the engineer moved me from one cable to another one and in doing so increased my Line Attenuation
4. At this rate it looks like I'm going to be stuck with slow broadband, compared to what I have had at Plusnet and at O2
5. Can you sort me out a replacement modem/router please as I need to eliminate the modem and the other problems I am having with it please.
6. Some thing is going on, just checked router and I now seem to have CRC and HEC errors .
19-03-2014 12:54 PM
Quote Well it looks like what ever he done yesterday has increased the Line Attenuation for no reason what so ever
Andy has noted this on the Fault Ticket and is taking action.
Quote 1. The interference/problem is still on and looks like it will be on for one of it's 4 days stints that it does, so can you sort out for BT to do a lift and shift as this is the only way I can see at the minute to help eliminate/fix the problem.
Our Faults Team will chase this for you. As I say, Andy is dealing with this personally.
Quote 2. I don't like the way the BT engineer had to come in to do his tests when he had the notes and was told not to and just raise a rein case instead
Agreed, again, something that Andy has noted on your Fault Ticket. Andy is chasing this for you.
Quote 3. I don't like the way that the engineer moved me from one cable to another one and in doing so increased my Line Attenuation
As noted above, this has been recognised and Andy will chase this with our suppliers.
Quote 4. At this rate it looks like I'm going to be stuck with slow broadband, compared to what I have had at Plusnet and at O2
I don't think that's a fair assumption to make as we're still investigating the issue. we're aware there is still an issue and Andy has this in hand and is working hard with our suppliers to rectify the fault. I appreciate that it's frustrating, however faults aren't always simple and straight forward to resolve.
Quote 5. Can you sort me out a replacement modem/router please as I need to eliminate the modem and the other problems I am having with it please.
We wouldn't send a replacement router out unless we believe that it is this at fault. If Andy believes the router is faulty, he will replace the hardware for you. As it stands, it doesn't look as though this is the case. I'm not saying it's not the router, I'm saying we can't send routers out on the off-chance that it might be that at fault.
Quote 6. Some thing is going on, just checked router and I now seem to have CRC and HEC errors .
Andy will be looking at this. Please give Andy some time to look at the fault. He's got other faults as well as yours to look at, but please do give him some time.
19-03-2014 3:37 PM
I do find it strange that BT will replace the cable from the exchange to the green cabinet but wont replace the 1970's aluminium cable that run from the green cabinet to the hole next to the pole, because I believe that if they done that it would help not just me but alot of people on the older cable and also give increase broadband speed, has he found yesterday while testing the old cable, went from 4700 on old cable to 5500 on new cable to the cabinet
On a side note my Download Speed is 2.76 Mbps, which I believe is below the 2.8 Mbps threshold or so I've been told ?
19-03-2014 5:18 PM
Quote On a side note my Download Speed is 2.76 Mbps, which I believe is below the 2.8 Mbps threshold or so I've been told ?
That could be quite right - still being investigated though and I'm sure Andy will spot that pretty quickly. I've sent Andy the link to this thread anyway, in case he fancies a read.
20-03-2014 7:24 PM
It's now gone back upto 10.6 dB on SNR, so what ever it is it's still happening and so good for the fix.
21-03-2014 10:38 AM
Now I really am annoyed at BT for moving me cables and messing me up, gone from 4700 kbps to now 3918 kbps
Quote DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 864 / 3,918
Data Transferred (Sent/Received) [kB/kB]: 9.66 / 10.86
Output Power (Up/Down) [dBm]: 12.6 / 0.0
Line Attenuation (Up/Down) [dB]: 35.3 / 57.5
SN Margin (Up/Down) [dB]: 5.4 / 6.1
Edit
Can any one tell me what Bit Loading, Bits/Tones mean please as I've seen spikes on top of the peaks in it when the interference/problem is on.
25-03-2014 5:58 PM
2. Whats the difference between Tie Pair Modification and Lift and shift. ?
3. Could see my DSL stats on the thompson router while the work was carried out but could not bring up link so doubt a lift an shift was done ?.
4. What ever the interference or problem is, it's still happening, graph added
5. This time can a REIN case be sorted out and BT engineer listen to what he is told and not come barging and insisting that he do his tests first.
6. Not Sure what is happening but Thomson 582n showing Line attenuation of 57.5 dB but Netgear DGN3500 showing Line Attenuation of 52.6 dB ?
25-03-2014 7:20 PM
Could it be faulty thomson router, faulty Netgear router or exchange problem still ?
26-03-2014 11:54 AM
Ideally the best thing to do would be to wait for Andy to continue getting further information from our suppliers and he should be in a good position to answer the questions you've put across to him on your Fault Ticket.
03-04-2014 4:56 PM
He could hear noise at the pole but could not see any errors on his machine and does not think it's a REIN problem but thinks instead that it's an exchange problem and that it is ok to have a slow speed and fluctuating SNR.
He suggested that the SNR be fixed at 6.0 dB, well sorry it is fixed at 6.0 dB, second BT engineer done that one .
He did suggest getting fibre to sort my problem out, Yeah ok just because you lot want to get out of doing your job and want me to pay more for broadband.
Now really annoyed with BT and there engineers and there attitudes towards me and for also not listening and being treated like I did know nothing about it or my problem and that this is normal and it's okay to have a slow speed compared to what I was getting
I do really wish that some one at Plusnet or BT would listen and rasie my upload speed back to 864 kbps, it's now at 446 kbps and to remove the banding or rasie the profile, having slow broadband speed again, well I think it's down to BT who are monitoring my line but dont want to admit it
Now I do really wish I had stayed with O2/Sky and now really do regret joining plusnet with BT that do not know what they are doing.
04-04-2014 11:05 AM
15-04-2014 8:42 PM
Had a call from Andy who now wants to close my case as BT have told him that they have come to dead lock on it and can't do nothing else now.
BT won't even send another REIN engineer out to make sure that it's the same source or a new source that is on now
So now I am stuck with a line that is slower then before I even contacted plusnet about the problem, Can only sync at 4000 on a good day with out the REIN on, was getting 4700 - 4800 before it all started and can only get about 2974 with the REIN on. ( I did have 4700 - 4800 with O2 for years)
Line attenuation gone up from 53.0 dB to 57.5 no one can tell me why, I think it's because I am on a different longer cable then before but now sure.
So now it looks like I am now even more screwed then I ever was before with a slower, crapper line and with Plusnet and BT that will not do a thing about it, so there moto is be thankful you have broadband at all or at least thats the message I am getting from Plusnet and BT, gets worse when Andy from PN who suggested that I contact ofcom for advice >:(, I mean come on what the hell have I been doing then talking to Plusnet and BT for then.
So thanks for the NO help and leaving me with a slower more rubbish line and for the poor 7 BT engineer attitudes that I've had
16-04-2014 9:50 AM
Unfortunately there is very little else we can do. As I've said on a few occasions previously, BT Openreach have investigated the REIN Issue as a gesture of good will. BT Openreach don't have to investigate or work to resolve the issue if it is outside of their domain.
BT Openreach are responsible for ensuring that any maintenance/provision/faults are dealt with on their network. If a shop sign with lights in is causing REIN for example, it's not up to BT Openreach to fix that unfortunately.
I appreciate the position that you're in, but there is very little we or our suppliers can do about a REIN Issue that is outside of our/their control. If you'd like to add any further notes in relation to this issue, I would advise adding them to your Fault Ticket for Andy to see.
16-04-2014 11:13 AM
Oh look it's doing it again connected at 4160 kbps but only getting 2463 kbps on speed test, time to moan on the phone again ::), some thing is not booting me back up again and loves to force me down low
Oh and if this is the way that BT and plusnet treat there customers then I do really wish that I could turn back time and stay with O2/Sky
16-04-2014 11:23 AM
Sometimes the most effective remedy s to go and knock on he door on the source and ask if they know they are interfering with everyone's phone systems?
Ofcom might be able to help here.
