Disconnection and drop in speeds
olisun
After more than 12 months of fault free service since I joined, I noticed today that my downstream speed has dropped by more than 10mb and my upstream by approx 5mb.
Can you please look into this for me?
Regards,
Oli
EDIT: My upload speed is back after a modem restart but my download speed still remains dropped.
The online profile shows my dl speed as 69.x whereas before it was 77.x
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Disconnection and drop in speeds
Hi olisun,
I'm sorry to hear that your speeds have dropped ever so slightly. I've taken a look at your line (stats attached to this post) and can see that your line has errored quite a lot which has forced the connection drop a couple of times.
<img src="http://community.plus.net/visualradius/generated/image14023892104397.png"/>
You can see that I've highlighted the number of 'Retrains' which shows the connection as had to restart due to excessive errors on the line. I would give the line around 9-10 days for DLM to pick things back up, assuming that your line remains error free.
Chris Pettitt
Cloud Environments Engineer
olisun
Can you please tell me on what date / time did the errors occur?
Regards,
Oli
Plusnet Staff
Plusnet Staff
Fixes: 5
At present we don't have that level of information I'm afraid. It's something we're working with our suppliers to provide us with to help us in future. I would suspect that the errors are at the times of the drops on the RADIUS graph though.
Chris Pettitt
olisun
I have been having some disconnections in the past and I have nailed it down to either a faulty modem psu or the power socket on the wall.
The power socket is located behind the sofa and with the slightest movement it caused the modem to switch off. This caused the speeds to drop by 10mb and it used to usually recover within a week.
But this time the speed has not recovered and yesterday there were 2 disconnections even when there were nobody in the house. And this has caused the speeds to drop even further.
Can you please reset my profile?
Regards,
Oli
Fixes: 62
To be honest - you need to sort out the underlying problem
More specifically with as you on fibre the only way to have a reset is with an engineer visit which is most unlikely to be agreed
Topic merged with your earlier thread for continuity
olisun
So are you saying that I am now stuck with the lower speed?
jim:quote
Fixes: 62
The only thing you can do is raise a fault here https://faults.plus.net
olisun
I have fixed the offending wall socket but I noticed that my speed has dropped ever further down to 45.8 Mb i.e a total of 30mb+ drop
If my speed doesn't get resolved I am off to VM atleast with their throttling the speeds are still faster than BT.
olisun
Speed down by 50% of the original speed and no response from Plusnet.
Current line speed:
   36.8 Mb
EDIT:
Is my profile set to the 40mbps speed?
Download speedachieved during the test was - 36.15 Mbps
For your connection, the acceptable range of speedsis 60 Mbps-36.98 Mbps .
Additional Information:
IP Profile for your line is - 36.98 Mbps
Upload speed achieved during the test was - 9.59Mbps
