Disconnection Issues
imitch
Over the last 2 days I have had problems with intermittant disconnection
Before that I had no problems
This afternnoon/evening it has been on and off like a YO-Yo
I have tried rebooting and the phone line seems to be OK
Can you shed any light on the problem
Thansk
3 REPLIES 3
Fixes: 345
Re: Disconnection Issues
@imitch Welcome to the forums.
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
The above assumes you still have 'normal' landline connection - if you have a SOGEA (internet only) one, just use the second link to report a network issue.
wufer
So im not the only one
Fixes: 345
Follow the suggestions above, @wufer
