Disconnect between 6-7 :/
MickHowes1
check my line i dsc between 6-7
Fixes: 65
Re: Disconnect between 6-7 :/
@MickHowes1
We're not seeing that reflected on our connection logs, however I'd not honestly be too concerned about a single disconnection as that can be quite normal. If that start to happens frequently you'd be best off raising a fault with us: http://faults.plus.net
Hope that isn't the case though, any concerns or questions then just drop us a reply.
Adam
 Adam Walker
MickHowes1
internet takes random lag spikes and disconnects me fromeverything for like 10 seconds upto bout 2-3 minutes:/ does it every so often
