Disapointing Service !
- Disapointing Service !
30-12-2007 10:03 PM
The above Id no. was a ticket that i raised a while ago regarding the service that i am receiving from Plusnet ! As a customer of 4+ years @ £21.99 a month, I am unable to Watch a download stream of 400kbs at peak time !
I pay this tarrif monthly regardless of my usage ! Is this because of Capping, Fair usage......... etc ? The Monies that i pay for this service is no way reflected in the Product that i receive !
I'm sure that you will agree ! If it is indeed because of Capping, Fair usage agreement, i will then move to a suitable provider ! Please let me know , many thanks Stuart.
Re: Disapointing Service !
31-12-2007 1:19 AM
Servers of downloads can get very congested, especially at peak time. If you want to discuss this publicly, you really need to supply additional info.
31-12-2007 11:09 AM
02-01-2008 2:12 PM
That ticket closed after our guys responded to you because you didn't reply within 14 days.
Could you possibly let us know if this is only affecting your streaming or is web browsing also slow?
We would need you to try running some tests as mentioned in your ticket.
02-01-2008 3:24 PM
Was warned that my connection speed would vary for the first 10 days which it did. It varied between 1.9 and 2.8 mbps for the first 7 days , and then it went up to an average of approx 5mbps
for about 3 days until yesterday when it dropped right down to approx .4mbps .
However, it was quite a coincidence that the speed dropped immediately after I had fitted my old NTL box to the incoming box . The reason I did this is because I will be changing to home phone on the 11th. .On the deal that I made with NTL years ago. If I spend more than £15 p.m on phone calls my Dial-up Internet is free 24/7 BUT, if I don't I still pay £15. Well I have only used about £7 this month, so, I thought I might as well have my £15's worth as I'm paying for it .
I disconnected the box immediately, later in the evening my speed improved to approx .7 mbps but not good . I happened to see that you can do a speedtest within the PN site which I did .
The results said that compared to previous tests this was not good, so I proceeded to fill in the fault checker. When I got to the point were it asked if I had made any changes, I of course said yes.
It then asked for more information on this. I thought this is going to be a lot easier to explain over the phone . So at 12.45am this morning I phoned PN.
I got an immediate reply from a real person in England speaking plain English
Also by the time I had finished speaking to him , he had sent me 2 emails 1 to say that the problem was being dealt with and to check back in 2hrs
The other to give me a free 0808 Dial -up number that I could use whilst the problem was being sorted in case I was unable to gain access through Broadband
I obviously didn't check back at 3am but did when I got up
The reply was, they could find no fault as such , but BT said that they felt that this was an acceptable level of speed .
I was invited to comment on the service .
My reply was , that although I was happy with PN's support service I did not accept BT's comment that 0.4 mb speed is an acceptable level when only hours before the speed was averaging 5mb.
PN immediately replied saying that Bt had not supplied any speed test info and could I do 3 speed tests preferably spaced out during today and that they would be doing further
investigations.
Based on this, I believe that Plusnet are offering a good service but BT are not.
02-01-2008 6:04 PM
Was the NTL box plugged in to a filter or direct in to the phone socket?
02-01-2008 7:07 PM
02-01-2008 7:18 PM
There's nothing Plusnet can do - you will just have to wait for the speeds to return.
02-01-2008 7:25 PM
For the sake of £6-7 and 8-9 days till I go on home phone I will not bother with the NTL box again.
As long the speed does return that's fine.
07-01-2008 8:44 AM
Since approx 9.30 am on the 2nd . I am a bit dissapionted that Bt have not now increased my speed, or do they not work week-ends?
07-01-2008 9:40 AM
This should pick up relatively shortly. I'm quite surprised to see that this hasn't updated yet as the last update was on NYD.
Hopefully it should pick up within the next 24 hours
07-01-2008 10:03 AM
It sounds like the nail has been hit on the head as to the source of the problem, you now appear to be out of pocket as a result of not using the NTL dialer box.
However, did you know....
You don't need to use the dialer box!!
This box is designed to intercept any numbers called and route them via NTL World if they meet a specific format.
This is just a method to automate it.
You can however continue to use your included minutes, by prefixing any number you dial with 1263.
If calling you support line for example, use 126301142965182
What is more, you can still use this service after you move to Home Phone with ourselves.
07-01-2008 3:01 PM
I did actually know that I could prefix it with a number, BUT
it's been so long since I used the number that I had forgotten what it was. Thanks for reminding me .
07-01-2008 3:32 PM
However, I've just tried again on Broadband.org and according to that , it has now gone back up to approx 4mb .
If it stays at that or higher I will be happy.
07-01-2008 11:23 PM
The first test was the plus net band width test which showed
4253.4 kbps
the second Bt's. The results below
Excuse my ignorrence , but why is one showing 4253.4 kbps and the other 3009kbps less than 5 minutes apart .
Do they use a diferent system & if so , how can you tell which one is correct ?
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 4500 kbps
DSL connection rate: 448 kbps(UP-STREAM) 5536 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 3009 kbps
