Disable usb port on HH2?
- Re: Disable usb port on HH2?
03-10-2012 10:34 AM
Does anybody know if I can disable or change the ip address of the usb port on the HH2?
The new PN fibre router's usb uses the same ip address and I want to use the HH2 for voip.
I know I can ignore the usb ports but I used the hh2 one for my printer and now have it connected to the PN router.
Message 1 of 3
(756 Views)
2 REPLIES 2
05-10-2012 7:17 PM
Don't know the answer, but the obvious question is are there any relevant things on the Settings tab if you log in to the HH?
And here's something of interest - http://bt.custhelp.com/app/answers/detail/a_id/11523/related/1 you ought to tell them the trick!
Edit: Is it a 2.0A or 2.0B?
Message 2 of 3
(362 Views)
06-10-2012 9:51 AM
Nope there is nowt on the settings or telnet menus.
That just says you maybe able to connect a printer, I had it working.
I have just ignored the usb ports for now and reconnected it to the main pc again.
Message 3 of 3
(362 Views)
