Disable interleaving on upstream?
robsdesk
Some time back I had a line fault which resulted in interleaving being enabled on my upstream connection (turned out to be a physical fault), as we know this has the effect of capping the upload back which when you don't have much in the first place hurts a bit!  Please could someone place a change to remove it from my line?
Kind regards,
Rob
