Disable TG582n DLNA server
Ottmar
How do I disable the DLNA server on a Technicolor TG582n?
Fixes: 6
Re: Disable TG582n DLNA server
Try:
Go to content sharing and turn off "manage disk".
May need to reboot the router.
Don't have a technicolor router running at present to check, so terminology may be a little off.
Ottmar
Thanks for pointing me in the right direction. Mission accomplished.
