Different speed quotes
- Re: Different speed quotes
23-10-2016 3:05 PM
Hi
SO at the moment I am on Plusnet and, after being moved to their new network, am happy with my speeds. I currently get a consistent speed test result of around 17 Mbps. However my current agreement is about to run out and they won't renew me with free Broadband again.
I called sky who will give me a years free broad band however they are quoting me speeds of between 6 and 12 Mbps. Why are they quoting me such a low speed? any ideas?
23-10-2016 3:20 PM
Hello there,
If you check your downstream line rate estimate at http://www.dslchecker.bt.com and if the target is below 17 Mbps like Sky are quoting you then it's likely that your line is just over performing (which is a good thing).
Something to bear in mind is that Sky sometimes use LLU equipment in exchanges, so if you were to move, your connection speed might change.
I hope this helps
23-10-2016 4:44 PM
that site tells me downstream range is 15 to 18 Mbps. I do know that my exchange has Sly listed as an LLU. I used to have sky a few years ago and got close to 20 Mbps so knot sure why its now quoting so slow.
Also would I be able to use my Sky Hub 1 with Sky as their Sky Hub is [-Censored-].
23-10-2016 6:03 PM
If you meant to say your Plusnet Hub One, I think the answer is no.
23-10-2016 7:14 PM
As far as I am aware, you can only use a Sky router with Sky. (From personal experience when I was with Sky 10 years ago. Things may have changed...)
