Different OS, Different speedtest result ...
- Different OS, Different speedtest result ...
02-02-2008 8:54 AM
When I run the BBMAX speedtest on my Acer laptop (wired) running XP Home SP2 using Opera I never get more than 5900 kbps down. Switching off ZA and AVG on the Acer makes no difference btw.
When I run it on one of my (old desktop) Linux boxes (wired) using Opera, I get about 6400 kbps down.
This is a consistent, repeatable result.
Ideas?
Paul
Re: Different OS, Different speedtest result ...
02-02-2008 9:15 AM
02-02-2008 12:03 PM
When you refer to wired I assume you mean Ethernet and not USB?
02-02-2008 1:21 PM
02-02-2008 8:56 PM
02-02-2008 10:57 PM
02-02-2008 11:04 PM
and speedtests don't "download updates" ...
03-02-2008 1:16 AM
However, in Mac OS X 10.5 (Safari) speeds are faster than WinXP (Firefox). A bit of RWIN tweaking has got XP up to speed however. I kow it's not a 'fair' test as I'm using different browsers.
Maybe pierre_pierre is correct - perhaps the implementation of TCP/IP in your Linux distro is better than the MS effort?
What happens if you try another browser on both OSes?
03-02-2008 2:42 AM
