Did I cause a DLM Profile change?
- Re: Did I cause a DLM Profile change?
18-02-2014 9:20 AM
For a couple of days there my router was connecting at 11556kbps but a day into it I had to turn my router off and on as my Xbox was complaining about an MTU error.
A day or two later my router then connected at 9643kbps, did I cause this with turning it off and back on again or is it because my line is noisy?
About 8 months ago I had an engineer out as I dropped from 1Mb to 0.2Mb and he changed me over at the telephone pole so I was getting a really good connection (10MB) but did state that the line was noisy.
Uptime: 2 days, 1:17:39
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1,147 / 9,643
Data Transferred (Sent/Received) [GB/GB]: 1.00 / 8.79
Output Power (Up/Down) [dBm]: 12.8 / 0.0
Line Attenuation (Up/Down) [dB]: 18.4 / 36.5
SN Margin (Up/Down) [dB]: 6.3 / 3.9
Loss of Framing (Local/Remote): 9 / 0
Loss of Signal (Local/Remote): 3 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 38,156 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 230 / 6,034
HEC Errors (Up/Down): 297 / 28,446
18-02-2014 10:45 AM
Depending on numerous conditions, such as external or internal interference can depend on the connection speeds you receive. There's always a risk when restarting your router that the connection rate can decline slightly. I wouldn't say it's anything to worry about though as your speeds are still pretty high.
18-02-2014 7:10 PM
I restarted it early in the morning about 5AM I think, I'll keep an eye on it as it's approaching the 72 hour mark which is when it should change back right?
If goes lower again then I can assume that it's the line.
19-02-2014 9:13 AM
21-02-2014 5:06 AM
It's been connected for 4 days and 21 hours, so by the time you read this it'll be 5.
What do you suggest?
21-02-2014 9:24 AM
21-02-2014 9:33 AM
But I need to turn off my router as my xbox 360 can't connect to xbox live.
21-02-2014 9:36 AM
21-02-2014 9:41 AM
21-02-2014 9:43 AM
21-02-2014 9:44 AM
21-02-2014 9:48 AM
Restarting your router can lead to your line becoming banded (http://community.plus.net/library/broadband/broadband-faults-guide-banding-guide/).
21-02-2014 9:51 AM
I've got it sorted, don't know how but I think it was the dns or ip address or something.
Is there any reason why I have high errors on my router?
21-02-2014 10:06 AM
21-02-2014 10:20 AM
Uptime: 0 days, 0:57:52
Bandwidth (Up/Down) [kbps/kbps]: 1,144 / 10,115
Data Transferred (Sent/Received) [GB/GB]: 2.00 / 28.52
Output Power (Up/Down) [dBm]: 12.5 / 0.0
Line Attenuation (Up/Down) [dB]: 18.5 / 36.5
SN Margin (Up/Down) [dB]: 6.4 / 3.1
Loss of Framing (Local/Remote): 17 / 0
Loss of Signal (Local/Remote): 4 / 0
Error Seconds (Local/Remote): 41,189 / 0
CRC Errors (Up/Down): 2 / 221
HEC Errors (Up/Down): 0 / 318
