Diagnosing a slow connection - your feedback requested
- Re: Diagnosing a slow connection - your feedback r...
12-01-2013 4:44 PM
The download speed used to be around 5Mb/s but it has now downgraded to under 0.5Mb/s.
The Plusnet technician said that the connection was suffering from multiple dropouts which
explained the slow speed, and requested me to do the usual checks including trying a different
router.
The only router available to us was one supplied by our previous provider O2, but amazingly this self
-configured to work on Plusnet and allowed us to connect to the internet. The download speed
remained unchanged at around 0.5Mb/s. To my mind this proved that the fault was not on our
premises and consequently we changed back to the original PlusNet router and I asked PlusNet to
escalate the problem to BT.
The technician then told me that I should have left the O2 router in place to see if the exchange
could negotiate a higher speed.
Surely, if the PlusNet router had been at fault, connecting the second router would have
immediately have given me a higher line rate. The fact that this did not happen suggests to me that the
PlusNet router is ok. I know it takes a while to negotiate a safe speed, but I expected some
immediate improvement.
I would appreciate your comments because I am trying to improve my understanding of how it
works.
Thanks Geoff
Re: Diagnosing a slow connection - your feedback requested
12-01-2013 5:14 PM
12-01-2013 5:28 PM
12-01-2013 5:35 PM
12-01-2013 5:44 PM
12-01-2013 6:51 PM
Uptime: 6:58
Bandwidth Up/Down: 440/572
Data Transferred: 3.74/1.74
O/P Power: 12.9/0.0
Line attenuation: 26.9/47.0
Noise Margin: 23.5/18.1
The account I am referring to is: eryca01
Thanks. I am hoping to get this problem fixed before next Thursday when our clubs use the computers.
12-01-2013 7:28 PM
I recommend you put the O2 router on again and keep an eye on the connection time. What you need to see is that you have a continuous connection of 24hours+. If that doesn't happen there is a fault which PN will need to get an engineer to investigate. If it does stay stable Plusnet can request a SNR reset which will put the margin back down to 6 or 9 and give you back your speed.
BTW: I hope for this fault identification process you are using the phone test socket.
12-01-2013 7:37 PM
http://community.plus.net/library/settings/testing-from-the-master-socket/
12-01-2013 8:42 PM
I have asked my colleague who lives near the site to reinstall the O2 router into the test socket as you say, and also disconnect the phone in case there is a fault on that.
Presumably if it is a router problem there should be some improvement after 12 hours with the O2, and PlusNet should be aware of any line drops?
I noticed that the line attenuation seemed quite good at 47dB on download, but presumably that is at the low current line rate?
Thanks for your assistance.
Geoff
12-01-2013 9:37 PM
To run the speed test go to http://speedtest.btwholesale.com/ and run the initial test. When that completes you need to then run the Further Diagnostics test which is accessed from the button at the bottom of the page.
After 24 hours please run the BT tests again and post the results.
Please then leave the router exactly as it is with no further reboots,even if after 24 hours you've seen no improvement. There's certain things we have to check along the way and we need to make sure we do things in the optimum order.
An attenuation of 47 should give you an IP Profile of around 5500.
14-01-2013 7:49 PM
unfortunately I was not able to get anyone to change back to the O2 router yesterday, so the Plusnet router has remained in situ since sometime Saturday afternoon.
I was told by Plusnet this morning that the line has been stable since 7pm on Saturday, with no more dropouts and they wanted to wait for 72 hours after that to see if the exchange recalibrates the line.
I have just rechecked again @7:30pm Monday, and the download speed is still aprox 0.5Mb/s. I logged into the router and the noise margin has reduuced from 18dB to just under16dB, but that is probably due to normal variation. I have been told not to get back to Plusnet until Tuesday evening when the 72 hours will be up.
It is possible that the dropouts were being caused by the microfilter which we have changed.
I am not convinced at all about this. Surely I should not have to wait 72 hours to see any improvement at all.
Any Comments?
Thanks Geoff
14-01-2013 7:56 PM
15-01-2013 4:20 PM
After two days of stability the line speed should have improved but it didn't due to some problem in the adaptive line management software in the exchange. All it needed was an SNR reset which I asked for yesterday and was denied. After only a few minutes the speed has increased from 0.5 to around 6Mb/s. I expect it will probably settle back down to a little less than this.
I think Plusnet need to slow down their growth rate until the standard of training has improved.
I hope Plusnet management read these postings.
Geoff
