Diabolical connection(!) in Lynton
keithjthomas
My connection in Lynton over the last few days is next to useless! Diabolical speed when it is connected and I'm lucky if I can get five minutes without the line dropping Angry!
1 REPLY
Fixes: 10
Re: Diabolical connection(!) in Lynton
Have you tried using the test socket?
Are you connected to the router wired or wireless? (If you are wireless you need to test wired)
Have you raised a fault? http://faults.plus.net
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
