Desktop cards or USB adaptor?
- Desktop cards or USB adaptor?
- « Previous
- 1
- 2
- Next »
Re: Desktop cards or USB adaptor?
25-01-2008 6:34 PM
I've used both and wouldn't really argue strongly in favour of one over the other as I've had not problems with either.
If you're prepared to have a go at opening up your PC that may be your best route in the long run.
25-01-2008 6:38 PM
28-01-2008 9:08 AM
Quote from: long I get 6.5Mbps using an Ethernet connection but found that it was only 4.5Mbps using a USB wifi connector (I assume this is due to the wifi overheads).
So having decided to stick with Ethernet, to eliminate the long cable connection, I now use Home Plugs (by Solwise) and find that they solve the problem completely (assuming your PC has an RJ45 socket of course )
Hi... still not made my mind up actually. My dad does have an old PCI card I could have for free, but still wary of opening the PC... just don't like doing it! There home plugs... is it safe to send the signal through a power supply?
28-01-2008 9:56 AM
Shut down the PC and remove the mains plug. Wait 30 seconds then remove the side cover (or the full cover), identify a free white PCI connector, remove any blanking plate covering the whole next to the PCI slot, push in the PCI card, screw it in and replace the cover. Refit the power cord and you are done.
The system should detect the PCI card and either have a driver for it already or use the driver disk/cd that came with the card.
As for the homeplugs, yes they are safe and just involves you plugging it into a free power outlet. It just uses frequencies within the home wiring that can only be detected by the home plug itself and has no effect any any powered equipment being used in the house.
28-01-2008 12:12 PM
1: Its relatively slow availability, since USB seems to be initialised relatively late in the boot process.
2: Wide variation in driver quality, on an XP system its probably worth crossing your fingers and hoping for built in support.
In addition I've found a tendancy to suddenly lose DHCP support, but I've also seen this with PC-card wireless.
28-01-2008 1:12 PM
Solwise homeplugs are safe but Netgear have just recalled 82,000 of theirs. See my post here.
28-01-2008 1:30 PM
So buying a brand new USB one with vista drivers already on etc appeals..
28-01-2008 9:59 PM
Quote from: mattdanielc cheers for the help guys as always. I use Vista (to those talking about XP) but really still not sure which one I will do... I guess the PCI card as it comes free, but the problem is I won't have access to any vista drivers until I can get online obviously!
If your using vista the I take it the computer not that old so my already have a Ethernet connection. My last 3 dell computers have and, my brand new Dell has wired and wireless connection
puddy
29-01-2008 12:50 AM
Maybe on a very fast PC it might not make a difference.
You do get PCI cards with external movable antenna on
cables.
29-01-2008 1:39 AM
I've had some awful problems with USB adapters from different manufacturers using Vista. "Temperamental" is the best way to describe it, while remaining polite!
If you do go for a USB solution and use a USB hub as suggested, make sure it is a powered one, and not one which draws its power from the computer - some WiFi USB adapters draw too much current to be powered through a hub which doesn't have its own supply. I've seen these give awful intermittant, or "total failure" results.
You can get internal cards with an extension lead and base for the aerial to let you position it where you need to. that would be my choice.
29-01-2008 8:47 AM
Thanks for the help re aerial location. Basically the router will be in the lounge literally directly below where the PC is in the spare room... so if the aerial is behind the computer, it actually ends up virtually on top of the router (if you see what I mean)
Going to install the wireless card tonight, hopefully all will work fine.
Puddy - yeah my PC is about 6 months old, also a DELL. I don't think it has a built in wireless connection though, as I don't remember choosing it, and there's certainly no aerial sticking out the back of it, so guess not.
29-01-2008 9:54 AM
- « Previous
- 1
- 2
- Next »
