Define: Other
Fixes: 4
Define: Other
What is the section marked other on my broadband usage?
Fixes: 12
Re: Define: Other
anything that is not covered or included in the listed categories.
Fixes: 62
Re: Define: Other
or that they can't identify
Fixes: 4
Re: Define: Other
Thats very wide isn't it Smiley
caravanj
Re: Define: Other
If you use a VPN it'll show as 'other'.
