Default Gateway
sparkalfa
Default Gateway
What should the default gateway be set to on a technicolor router on ADSL in the TCP/IP settings it's set to a 195.xxx.xxx.xxx address at the moment. Should it be the routers address?
Mark
1 REPLY
RPMozley
Fixes: 5
Re: Default Gateway
That is your current PlusNet gateway on to the wider internet. It is nothing to be concerned about and will automatically change if you get disconnected for some reason.
That's RPM to you!!
