Decreasing speed values
harps1h
Hi
I have a ticket into yourselves about my speed. Three weeks ago it was at 20.88 according to speedtest.net, tonight however it is down to 14mb and in the early hours of this morning when you thought it would record a better speed it was at 9mb. this is on a profile that was sitting at 21.45mb but has started to sink to 18.21. I have had similar problems to this on the old ADSL where my speed normally was at 6.72 then would drop down to about 1.2mb. However I thought the upgrade to ADSL2+ would have solved this. Alas not.
FYI Router stats are:
Link Information
Uptime: 1 day, 21:43:35
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1.247 / 20.639
Data Transferred (Sent/Received) [GB/GB]: 1,99 / 1,75
Output Power (Up/Down) [dBm]: 11,9 / 0,0
Line Attenuation (Up/Down) [dB]: 3,0 / 8,5
SN Margin (Up/Down) [dB]: 6,4 / 6,0
Loss of Framing (Local/Remote): 17 / 0
Loss of Signal (Local/Remote): 2 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 71.864 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 46 / 28
HEC Errors (Up/Down): 35 / 22
Fixes: 21
Re: Decreasing speed values
Do you have a problem with your line perhaps, that's causing loss of sync with the exchange?
Hi harps1h,
I've chased this up for you, ticket #57760086 has been updated, tests are currently being performed and you'll have an update soon from them.
If you need any help with this then let me know.
Your fault ticket #57760086 has been updated with the results from your tests, everything does look OK on your line. Have a look at the update it's explained more in depth there.
