Dead Zone - Spot the Difference
Velocity
Wow what happened tonight Huh
This is the Norm...
NEXT TEST
And The Following
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
C:\Users\V>tracert bbc.net
Tracing route to bbc.net [63.172.252.242]
over a maximum of 30 hops:
 1     4 ms     4 ms     4 ms  . [192.168.2.1]
 2    23 ms    23 ms    23 ms  lo0-central10.pcl-ag04.plus.net [195.166.128.185
 3    24 ms    24 ms    24 ms  link8-central10.pcl-gw02.plus.net [84.93.249.110
 4   114 ms   118 ms   116 ms  xe-1-2-0.pcl-cr02.plus.net [212.159.1.6]
 5   142 ms   133 ms   133 ms  ae2.pcl-cr01.plus.net [195.166.129.6]
 6     *        *        *     Request timed out.
 7   112 ms   113 ms   111 ms  10gigabitethernet1-1.core1.lon1.he.net [195.66.2
24.21]
 8   181 ms   185 ms   179 ms  10gigabitethernet7-4.core1.nyc4.he.net [72.52.92
.241]
 9   199 ms   200 ms   197 ms  10gigabitethernet8-3.core1.chi1.he.net [72.52.92
.178]
10   224 ms   221 ms   225 ms  10gigabitethernet3-3.core1.mci3.he.net [184.105.
222.118]
11   211 ms   210 ms   210 ms  united-private-networks.gigabitethernet1-7.core1
.mci3.he.net [216.66.78.74]
12   215 ms   211 ms   212 ms  e-1-1-arl-ne.static.nebraskalink.com [199.58.136
.5]
13   143 ms   143 ms   144 ms  199.58.136.177.dynamic.nebraskalink.com [199.58.
136.177]
14   224 ms   225 ms   224 ms  bbc.net [63.172.252.242]
Trace complete.
C:\Users\V
SELF HEALING LOTION SEEMS TO BE HAVING A POSITIVE EFFECT  Cheesy Smiley
http://www.speedtest.bbmax.co.uk/results.php?t=1359501119&v=18608016
Date of Speed Test: 2013-01-29 23:11:59
Download Speed: 68664 kbps (8583 KB/sec transfer rate)
Upload Speed: 17562 kbps (2195.3 KB/sec transfer rate)
SEEMS to be BACK
Fixes: 21
Re: Dead Zone - Spot the Difference
Could be a one-off. What does the next test get?
Oxslow
Fixes: 21
@Velocity, obviously you are suffering the same problems as the rest of us mentioned in the 2 threads posted by Oxslow now you've posted additional results.
« Last Edit: Today at 22:34 by Velocity »
Velocity
Thanks for the rapid response to inform and assist me.  Smiley
Just joined recently, and despite some small initial problems, it feels good to be here
Fixes: 21
Try running some tests again, pretty much back to normal with me at the moment.
Velocity
Hopefully this is a '1 off ' ...
Back to Business, just d/l a file at a constant 9.5MB/s
but I still find some browsing to be slow
Fixes: 21
Plusnet seem to have a Network problem somewhere at the moment at peak times, keep an eye on those other threads. Hopefully they'll get it fixed soon. Mind you, some BT customers are having problems on Fibre at peak times, whether it's an issue in BT's network or not is difficult to say.
Fixes: 4
It seems to have been across a whole load of Gateways last night, as well as the usual sispects. No doubt the day shift will provide an explanation.
It's looks like it's what we're currently aware of and looking into <a href="http://community.plus.net/forum/index.php/topic,111170.0.html">link</a>
Velocity
Good to know the problem is being investigated.
