Data extension cable query
- Data extension cable query
13-01-2013 9:44 PM
I am thinking of asking the engineer to set up a data extension cable about 5 - 6 metres long as my master socket is placed in conveniently in the hallway.. I had couple of queries about it...
1) Will it have any significant negative impact on net speeds by using a 6 m extension cable?
2) If I feel it has a negative effect on speed will I be able to discard the extension kit and plug in the modem directly to master socket easily?
Message 1 of 6
(1,215 Views)
5 REPLIES 5
Re: Data extension cable query
13-01-2013 9:45 PM
No. Yes.
Message 2 of 6
(725 Views)
13-01-2013 10:06 PM
When i had my install , BT man moved my master socket where i needed it data extension cable nice tea & bikkies
Message 3 of 6
(725 Views)
14-01-2013 8:22 AM
thanks guys...
i will then aim to place the router and modem in a corner of my living room.
Message 4 of 6
(725 Views)
14-01-2013 8:33 AM
In my experience the engineer tends to relocate the master socket. If they do then the answer to 2 is 'no'. The extension cable shouldn't have a noticeable impact your speeds though.
Message 5 of 6
(725 Views)
14-01-2013 9:04 AM
thanks bob... i will check with engineer about my question 2 before deciding..
it seems the answers to question 1 is unanimously positive which is a good start..
Message 6 of 6
(725 Views)
