DSL sync problems and very slow speeds when working.
- Re: DSL sync problems and very slow speeds when wo...
21-12-2012 12:27 PM
Yesterday I had no internet all day until around 10pm when it decided to work for around an hour before dieing again. Today it's worked a few times, but not for long.
There was some pretty bad weather before my internet started playing up. So just wondering what the problem could be and if it'll sort it's self out over time.
These are the stats my router is showing at the moment:
DSL Connection
Link Information
Uptime: 0 days, 0:57:45
DSL Type: G.992.1 annex A
Channel mode: Interleave
Maximum Bandwidth (Up/Down) [kbps/kbps]: 812 / 384
Bandwidth (Up/Down) [kbps/kbps]: 768 / 256
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 11.57
Output Power (Up/Down) [dBm]: 12.0 / 14.0
Line Attenuation (Up/Down) [dB]: 31.5 / 58.0
SN Margin (Up/Down) [dB]: 10.0 / 11.5
Loss of Signal (Local/Remote): 4 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 131,161 / 0
FEC Errors (Up/Down): 598 / 42,965
CRC Errors (Up/Down): 516 / 4,211
HEC Errors (Up/Down): 537 / 5,696
Doing a speed test on my ipad (my speeds are usually the same while using my pc using ethernet cable) I'm getting a download speed of 0.21Mbps and upload of 0.03Mbps.
Last time I did a test on my ipad while my internet was going normal speeds, I got 1.92Mbps download.
If you need any more info I'll try and reply. (if my internet is working, so I can. Lol).
Re: DSL sync problems and very slow speeds when working.
21-12-2012 1:01 PM
It looks like your recent drops in connection have caused your line to have slower speeds, this is managed by Dynamic Line Management (DLM) at your exchange.
Your recent connection graph:
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13560945259738.png"/>
There's something causing this to drop, I'd suggest running through the checks at http://faults.plus.net and if this doesn't solve it we can take over from there.
Chris
21-12-2012 1:31 PM
I don't use the home phone, the phoneline is just used for my internet. Anyway, I started working my way through the questions on that link you posted, and got to the question asking if the line is noisey and if theres a dial tone. I plugged in a phone and all I hear when I listen is a hissing sound, no dial tone.
I guess the bad weather is the cause. If theres a thunder storm my internet always dies, and while there wasnt any thunder, it was really windy and loads of rain the day it started messing up.
21-12-2012 1:41 PM
21-12-2012 2:16 PM
What should I do now? Try the router in the test socket and see if that makes any difference? I have an old thomson v7 router which I'm not sure works properly, but I could try that I guess. I don't want to keep messing about unplugging things and make my speeds even worse though (if thats even possible with my speeds at the moment, lol).
If the bt site is saying it's probably something my end, I don't want to get someone out and then be charged.
*update*
Just did a bt speed test on my pc connected to my router via ethernet cable and these are the results:
0.06Mbps download
0.00Mbps upload
41.25 latency
With speeds like that I guess it doesn't matter about unplugging stuff...
21-12-2012 3:32 PM
Have you tried more than one handset to confirm it's not the phone?
21-12-2012 4:06 PM
I'v plugged in my old thomson v7 into the test socket and getting the same speeds (around 0.22Mbps). But at least unlike my v8, this one can actually keep a wifi connection for more than 5 minutes. (which is great because I spend most my time on my ipad).
I haven't had the dsl error since plugging in the other router (don't think thats the router's doing though, lol), so hopefully that'll be the last of it and I can slowly get my speed back up.
Ps I saw on the bt site that I might get bt infinity in my area around the 31st of march. Does that mean There will be a plusnet equivalent in my area too, or is that a bt-only thing? My phone line has been nothing but a nightmare, if I can get internet by another means that'd be great!
21-12-2012 4:26 PM
It depends what it's syncing at really and if it holds the connection longer at a higher speed than the v8 - any chance you could paste the stats in here please?
Re fibre, I believe the 31st March is a holding date, my exchange (sharrow) is showing the same unfortunately. However, yes - as soon as Infinity is available for you you can also get fibre from us Hope it is enabled soon!
21-12-2012 4:45 PM
DSL Connection
Link Information
Uptime: 0 days, 1:46:16
Bandwidth (Up/Down) [kbps/kbps]: 640 / 928
Output Power (Up/Down) [dBm]: 12.5 / 15.5
Line Attenuation (Up/Down) [dB]: 31.5 / 60.0
SN Margin (Up/Down) [dB]: 11.0 / 9.5
FEC Errors (Up/Down): 0 / 57,154
CRC Errors (Up/Down): 0 / 916
HEC Errors (Up/Down): 0 / 309
21-12-2012 4:56 PM
Now to see if your line will remain stable.
21-12-2012 5:05 PM
