DSL stats for TG582N
- Re: DSL stats for TG582N
27-09-2013 8:48 PM
Having just had Essentials Fibre installed, the TG582N Gateway only shows info concerning WAN rather than DSL which I would like to keep an eye on. Is there any way I can get this info other than the BT Wholesale speed checker?
Message 1 of 7
(1,296 Views)
6 REPLIES 6
27-09-2013 8:55 PM
Not without hacking the BT modem - Not recommended
Message 2 of 7
(729 Views)
28-09-2013 9:03 AM
So is there any other means by which I can view up to the minute up/download speeds?
Message 3 of 7
(729 Views)
28-09-2013 9:43 AM
Only via the BT speedtest which gives the variable downstream profile but a fixed upstream profile
Message 4 of 7
(729 Views)
28-09-2013 12:31 PM
Thank you Oldjim. Have you any info on whether 'Router Stats' programme will work with my set up please?
Message 5 of 7
(729 Views)
28-09-2013 1:36 PM
it may but it still won't give you any useful information as the router doesn't know anything about the internet connection as that is all handled by the modem
Message 6 of 7
(729 Views)
28-09-2013 4:00 PM
In case it may be of use, a senior member of the Kitz forum has produced a router monitoring program to work with Broadcom based routers. Thomsons work with it subject to some minor limitations.
See here.
See here.
Message 7 of 7
(729 Views)
