DSL openreach led flashing. How long to resolution of my current TKT?
- DSL openreach led flashing. How long to resolution...
01-06-2013 12:01 PM
Anyone else got Fibre problems in the Derry area?
Started last night between 7pm and 11pm.
I have a TKT open and I wish to know how long until resolutuion?
Thank you.
Thank you.
Message 1 of 8
(1,484 Views)
7 REPLIES 7
Re: DSL openreach led flashing. How long to resolution of my current TKT?
01-06-2013 4:16 PM
Have a look at the BT Faults page
Me personally I can't see anything about Derry area. Try opening a Faults ticket using the Broadband troubleshooter rather than a normal ticket.
Hope this helps
Jamie
Hope this helps
Jamie
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up
Message 2 of 8
(688 Views)
01-06-2013 4:30 PM
@myjess
The BT Faults page isn't showing anything relevant. I take it your phone still works?
Try logging into the Router and go to the Internet Box. If it shows Connect, click on it. If it shows Disconnect, click on it, wait 30seconds and then click Connect.
HTH.
HTH.
Message 3 of 8
(688 Views)
02-06-2013 8:32 AM
I did all that, no difference, still will not connect, says concentrator noe reachable.
The openreach box wassitting behind the tv untouched. The wiring was untouched.
The nearest problem that BT says there is, is dunamanagh which is a village about 6 miles from me.
Thanks for your help.
Message 4 of 8
(688 Views)
02-06-2013 9:16 AM
How close are phone numbers beginning with the following Rathfriland- 0284063 & Crumlin- 02894 ?
Message 5 of 8
(688 Views)
02-06-2013 10:51 AM
Over 60miles .
Thank goodness for mobile broadband from that company with THREE + two letters in the name
Message 6 of 8
(688 Views)
02-06-2013 11:25 AM
You obviously don't mean 4gee then
Sounds like it could be just your line, unfortunately ticket responses aren't that quick at busy times.
Is your landline working Ok, Can you hear/have you heard any crackling or other noises on the line when using the phone? Have you had any problems with incoming or outgoing calls?
I'd try ringing in from your landline 0800-432 0200 free call, queues don't seem too long at the moment, quote your existing open ticket and ask them to run a test whilst you are on the phone.
Message 7 of 8
(688 Views)
02-06-2013 2:19 PM
Hi myjess,
I'm really sorry to hear that you're having problems with your connection.
If you are seeing a flashing DSL Light, that usually tells us that there is a synchronisation issue between the Cabinet and the Openreach Modem.
It can take up to 72 hours for us to investigate this issue from the time you raised the ticket.
Message 8 of 8
(688 Views)
