DSL keeps disconnecting
- Re: DSL keeps disconnecting
13-03-2014 8:26 PM
These are the current stats.
DSL Connection
Link Information
Uptime: 0 days, 0:34:00
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 615 / 9.647
Data Transferred (Sent/Received) [MB/MB]: 8,10 / 216,28
Output Power (Up/Down) [dBm]: 12,8 / 0,0
Line Attenuation (Up/Down) [dB]: 19,2 / 34,5
SN Margin (Up/Down) [dB]: 7,4 / 4,9
Loss of Framing (Local/Remote): 8 / 0
Loss of Signal (Local/Remote): 2 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 80 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 11 / 1.322
HEC Errors (Up/Down): 6 / 25.338
13-03-2014 8:37 PM
DSL Connection
Link Information
Uptime: 0 days, 0:01:12
Bandwidth (Up/Down) [kbps/kbps]: 251 / 9.979
Data Transferred (Sent/Received) [MB/MB]: 9,96 / 231,17
Output Power (Up/Down) [dBm]: 11,3 / 0,0
Line Attenuation (Up/Down) [dB]: 19,4 / 34,5
SN Margin (Up/Down) [dB]: 16,1 / 3,6
Loss of Framing (Local/Remote): 25 / 0
Loss of Signal (Local/Remote): 5 / 0
Error Seconds (Local/Remote): 205 / 0
CRC Errors (Up/Down): 0 / 138
HEC Errors (Up/Down): 0 / 2.906
I noticed the SN is all over the place.
13-03-2014 9:03 PM
14-03-2014 6:47 PM
15-03-2014 5:04 PM
17-03-2014 1:17 PM
Information
Uptime: 0 days, 15:34:08
Bandwidth (Up/Down) [kbps/kbps]: 360 / 9.803
Data Transferred (Sent/Received) [MB/GB]: 178,50 / 1,99
Output Power (Up/Down) [dBm]: 12,7 / 0,0
Line Attenuation (Up/Down) [dB]: 19,7 / 35,0
SN Margin (Up/Down) [dB]: 17,6 / 10,4
Loss of Framing (Local/Remote): 133 / 0
Loss of Signal (Local/Remote): 17 / 0
Error Seconds (Local/Remote): 1.101 / 6
FEC Errors (Up/Down): 13 / 6.519
CRC Errors (Up/Down): 0 / 54
HEC Errors (Up/Down): 0 / 563
Can some one look into this please?
Ticket 82863911
17-03-2014 1:56 PM
17-03-2014 1:58 PM
To prove that nothing internal is causing this issue, could you please connect your router into your Test Socket with an alternate microfilter?
17-03-2014 4:52 PM
17-03-2014 5:20 PM
Does your line just cut out altogether, as in, you have no dial tone at that point?
17-03-2014 5:39 PM
17-03-2014 6:08 PM
18-03-2014 2:35 PM
Let me know if you spot any oddities.
19-03-2014 8:23 PM
19-03-2014 11:32 PM
Do you still get noise on the line without the router connected?
