DSL down for 2 hours
hamilton36
I cannot connect to broadband. DSL down. Broadband light flashing on the router; internet light out ..... and it has been like that for over 2 hours.  Lucky I still have Pentium 1 and Win98 that works direct off a 'phone line, otherwise I would not be able to contact you at all.
What are you doing?
Alex
Plusnet Alumni (retired) LinnPlusnet
Re: DSL down for 2 hours
Hi hamilton36,
Really sorry to hear you've lost connection.
We've ran a test and can see that you've lost sync. Can you raise us a fault here: http://faults.plus.net so that our Faults team can raise this to our suppliers?
Hopefully this will be resolved for you soon.
hamilton36
Linn K,
That link does not bring up the required page and with 56k modem I am not surprized.  You raise the fault please!  What would you have  done if I did not have an old computer and could not contact you at all?  Well! Do that now and asap, please!
Thanks,
Alex
Fixes: 62
You could phone in - current wait time is very little
    0800 432 0200
    0345 140 0200
hamilton36
Thank you Old  Jim. Just spoke to Chris; did the checks on the lines in the house and an engineer has been booked for Saturday morning.
Thanks again,
Alex
hamilton36
Just to let you know that the BT engineer has been and I have Internet connection again.  Aparently, they did some work on fibre broadband last Thursday I was wrongly connected to that.  The engineer described it as a "self-inflicted" fault.
Thanks again for your help on this. Much appreciated.
Best regards,
Alex
No doubt this is what happened - http://www.okcheersbye.co.uk/kelly-communications/
