DSL connection is down
Horace935
I have reported a fault to plus net to which they sent me a email telling me how to go into the router settings which I have done and changed the internet username and password
I now get an error message saying the DSL connection is down
The wiring is all correct from the socket to the router - could this be a fault with the router - or is there anything else I can try
hitchhiker43
Fixes: 4
Re: DSL connection is down
was the connection down before you changed the username and password ?
Tp-link W8960n on longgggggggg line!
markhawkin
Fixes: 5
@Horace935
Assuming the configuration of the router has no value to you (no special settings), it is a Plusnet "issue" router and you obtained it directly from Plusnet, resetting it and letting it pick up the configuration might fix everything.
