DSL connection is down
why678
I am living in Sidcup and My plusnet connection is suddenly down this evening. I have changed to use a new ADSL filter socket, checked the line and used testing socket to connect but still doesn't work. Could you help to check for me urgently? Thanks.
Fixes: 152
Re: DSL connection is down
Hi there.
I can see you've called in this morning and we've identified a issue with the telephone line which is causing your connection to be down.
Once this has been resolved your connection should be working again but if your still having issues please let us know.
 Matthew Wheeler
why678
Hi Matthew,
Thanks. Could you know when the telephone line will be fixed? I got a SMS that it will be fixed on 17/Dec. could it be possible that will be fixed earlier?
Thanks,
Derek
Plusnet Staff
Plusnet Staff
I've just checked your account. The 17th is an estimate given by Openreach. It's possible it will be sooner, but I've also see them take longer. It just depends on the complexity of the issue.
Tony
 Tony
 Plusnet Support
why678
Quote from: plusnettony
Tony
That's done now. Everything back to normal. Many thanks for your help!  Wink
Fixes: 152
Glad to hear that's been fixed for you.
If you have any further issues let us know.
 Matthew Wheeler
