DSL connection is down
- Re: DSL connection is down
26-09-2016 7:26 PM
I have reported a fault to plus net to which they sent me a email telling me how to go into the router settings which I have done and changed the internet username and password
I now get an error message saying the DSL connection is down
The wiring is all correct from the socket to the router - could this be a fault with the router - or is there anything else I can try
Message 1 of 3
(707 Views)
2 REPLIES 2
27-09-2016 8:46 PM
was the connection down before you changed the username and password ?
Tp-link W8960n on longgggggggg line!
Message 2 of 3
(650 Views)
27-09-2016 8:58 PM
Assuming the configuration of the router has no value to you (no special settings), it is a Plusnet "issue" router and you obtained it directly from Plusnet, resetting it and letting it pick up the configuration might fix everything.
Message 3 of 3
(643 Views)
