DSL connection is down
- Re: DSL connection is down
12-12-2014 8:45 PM
I am living in Sidcup and My plusnet connection is suddenly down this evening. I have changed to use a new ADSL filter socket, checked the line and used testing socket to connect but still doesn't work. Could you help to check for me urgently? Thanks.
Message 1 of 6
(1,492 Views)
5 REPLIES 5
13-12-2014 9:48 AM
Hi there.
I can see you've called in this morning and we've identified a issue with the telephone line which is causing your connection to be down.
Once this has been resolved your connection should be working again but if your still having issues please let us know.
Message 2 of 6
(723 Views)
13-12-2014 2:39 PM
Hi Matthew,
Thanks. Could you know when the telephone line will be fixed? I got a SMS that it will be fixed on 17/Dec. could it be possible that will be fixed earlier?
Thanks,
Derek
Thanks,
Derek
Message 3 of 6
(723 Views)
13-12-2014 5:29 PM
I've just checked your account. The 17th is an estimate given by Openreach. It's possible it will be sooner, but I've also see them take longer. It just depends on the complexity of the issue.
Tony
Tony
Message 4 of 6
(723 Views)
19-12-2014 4:35 PM
Quote from: plusnettony I've just checked your account. The 17th is an estimate given by Openreach. It's possible it will be sooner, but I've also see them take longer. It just depends on the complexity of the issue.
Tony
That's done now. Everything back to normal. Many thanks for your help!
Message 5 of 6
(723 Views)
19-12-2014 4:38 PM
Message 6 of 6
(723 Views)
