DSL Routers
numpty
DSL Routers
Hi
    the question is should I turn off my router at night or when not in use  or should I leave it on 24/7.
The machine in question is a Netgear 2200 v3
        Undecided    Regards Numpty
Estragon
Re: DSL Routers
Whichever you prefer. Just don't turn it on and off several times a day. (Though within reason even that shouldn't be an issue).
Fixes: 23
Re: DSL Routers
It depends on how you turn it off.  The best way is to log on to your router, disconnect the PPP session (Router status - Connection Status - Disconnect) then switch it off.  You may also find that you need to wait until daylight to reconnect at the fastest speed when you turn it on again.
198kHz
Seasoned Pro
Fixes: 9
Re: DSL Routers
Is there a particular reason you'd want to turn it off at night?
I've tested a few different routers, and they all drew about 10W from the mains, so that's only around £10·50 per annum if left on.
I'm inclined to think that the electronics would probably last longer, too.
Papyrus and Comic Sans walk into a bar. The bartender says, "Get out -- we don't serve your type."
Fixes: 46
Re: DSL Routers
Yes, most electronic devices come under more strain from being powered on and off than being left on.
 Adam Walker
numpty
Re: DSL Routers
Thanks Adam
                            I will follow your advice and leave the beast on.
        Regards Numpty  Smiley
