DSL Dropout
mactell
DSL Dropout
I've noticed my broadband has dropped out a number of times today due to the DSL connection. Is it possible to run a line test in the members area? Or do I need to phone up.
9 REPLIES 9
MatthewWheeler
Fixes: 436
Re: DSL Dropout
Sorry to hear you've had issues with your connection.
Unfortunately you can't test the line yourself but I've just tested your line for you.
It's not shown any cause for this but from what I can see it's now stable.
Hopefully it was just a blip but if the drops continue I'd recommend raising a fault here.
 Matthew Wheeler
mactell
Re: DSL Dropout
Hi @MatthewWheeler,
Thanks for confirming there is no fault on the line. Out of interest, would you be able to do a profile reset on my line. I'd be interested to see if my speeds increase as they never seem to fluctuate which seems to me like a stuck profile.
Thanks!
MatthewWheeler
Fixes: 436
Re: DSL Dropout
Unfortunately we can't just request profile resets on fibre as there has to be certain criteria met and in this case it wouldn't make any difference as your current profile is "0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off" which is the best profile you can get.
Your upload speeds are a bit lower than expected so it may be worth going through the steps here if you haven't done so already
 Matthew Wheeler
mactell
Re: DSL Dropout
Hi @MatthewWheeler,
Thanks for getting back to me. I thought they were a little lower. I will try the troubleshooting steps tonight but I don't think It will do anything. What sort of speeds would you expect me to get (My assumption would be 20mb, or as near as rather than 10Mbps)? If the troubleshooting steps don't work tonight, what would be the next step?
Kind Regards
MatthewWheeler
Fixes: 436
Re: DSL Dropout
Your estimated speeds are shown below
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
  High Low High Low
VDSL Range A (Clean) 78.5 55.7 20 14.8 49 Available Available --
VDSL Range B (Impacted) 66.3 40 18.6 9.9 33.6 Available Available --
The download speeds are just within the estimates but the upload could be better
 Matthew Wheeler
mactell
Re: DSL Dropout
Thanks @MatthewWheeler. So if the troubleshooting steps you provided earlier don't work then what would be the next steps?!
MatthewWheeler
Fixes: 436
Re: DSL Dropout
If the speeds still haven't increased we'd recommend raising a fault here
 Matthew Wheeler
mactell
Re: DSL Dropout
Hi @MatthewWheeler,
None of the steps have helped at all. Still producing the same speeds...?
What now? I don't want to raise a fault if I'm going to be charged for it.... But I can't see how it could be anything else. My BT openreach modem is plugged directly into the mastersocket all the time.
MatthewWheeler
Fixes: 436
Re: DSL Dropout
Sorry to hear you still haven't seen a increase.
With regards to the charge this is only applied if the fault is found to be internal, damage to BT equipment or if they can't find a issue.
Ultimately it's down to yourself how you want to proceed
 Matthew Wheeler
