DNS
- DNS
Re: DNS
18-05-2013 8:35 PM
and found various things about DNS amplification attacks, so I'm guessing the 20 or 30 second delay is some sort of security feature?
Which finds another domain Plusnet DNS returns SERVFAIL for: dns-oarc.net - The Domain Name System Operations Analysis and Research Center (DNS-OARC).
It can't be a coincidence that isc.org, ripe.net and dns-oarc.net are all large Internet infrastructure related entities.
Re: DNS
18-05-2013 8:48 PM
Quote from: ejs
Good point.
But it's still only Plusnet DNS which has the problem.
Lookup time for ripe.net
root servers == 31 ms
google dns == 46 ms
Plusnet DNS == connection timed out.
Edit 9:30pm
212.159.6.9 has started working for me
212.159.6.10 still has problems plus an additional 4 urls it has problems with.
nominet.org.uk
verisigninc.com
nlnetlabs.nl
kirei.se
Re: DNS
19-05-2013 6:43 AM
Re: DNS
19-05-2013 6:51 AM
But I have noticed that Plusnet's DNS servers now don't respond to type ANY queries (requests for all records), I don't remember if they did before:
[tt]$ dig @212.159.6.9 plus.net ANY
; <<>> DiG 9.9.2-rl.028.23-P2-RedHat-9.9.2-10.P2.fc18 <<>> @212.159.6.9 plus.net ANY
; (1 server found)
;; global options: +cmd
;; connection timed out; no servers could be reached
$ dig @212.159.6.9 plus.net NS
; <<>> DiG 9.9.2-rl.028.23-P2-RedHat-9.9.2-10.P2.fc18 <<>> @212.159.6.9 plus.net NS
; (1 server found)
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 8786
;; flags: qr rd ra; QUERY: 1, ANSWER: 2, AUTHORITY: 0, ADDITIONAL: 2
;; QUESTION SECTION:
;plus.net. IN NS
;; ANSWER SECTION:
plus.net. 23693 IN NS ns2.force9.net.
plus.net. 23693 IN NS ns1.force9.net.
;; ADDITIONAL SECTION:
ns1.force9.net. 85841 IN A 195.166.128.16
ns2.force9.net. 85841 IN A 195.166.128.17
;; Query time: 19 msec
;; SERVER: 212.159.6.9#53(212.159.6.9)
;; WHEN: Sun May 19 06:49:52 2013
;; MSG SIZE rcvd: 101
[/tt]
Re: DNS
19-05-2013 10:05 AM
Quote from: ejs
Borked.
Re: DNS
20-05-2013 8:18 AM
I question whether SamKnows reporting is showing the correct time. I have suspected it was adrift since I first got the whitebox, but my connection is so stable that until now I have not been able to correlate any timed events to confirm my suspicion.
Yesterday outside my house an electricity supply pole got damaged, the power company had to come out to replace the pole and the feed cables to the group of houses. In doing so we had a power cut from almost exactly midday until just before 16:00.
This can be seen on my TBB ping graph -
My SamKnows box doing hourly tests for latency shows this -
The SamKnows reporting has three missing results at 11:00, 12:00, and 13:00, but is back at 14:00.
The TBB ping graph which IS showing the correct time would suggest that the missing three results should be at 13:00, 14:00, and 15:00.
My SamKnows reporting is set to "Timezone : (UTC 0) United Kingdom/London", but the results appear to be 2 hours adrift.
Therefore the apparent DNS glitch on the 17th May was probably at midday rather than 10:00 as indicated !
Re: DNS
20-05-2013 10:50 AM
Re: DNS
20-05-2013 10:54 AM
Re: DNS
20-05-2013 10:59 AM
Re: DNS
20-05-2013 12:48 PM
The corresponding SamKnows graph shows one missing 'on the hour' test, and that is for 10:00 as I suspected.
Therefore my SamKnows reporting graphs are all 2 hours adrift !
Looks like I need to raise yet another issue with SamKnows !
Re: DNS
20-05-2013 1:23 PM
Anyway, all will become clear a bit later on
Sorry i've gone off topic people, but i thought it worth mentioning.
Re: DNS
20-05-2013 5:13 PM
Re: DNS
20-05-2013 5:54 PM
If it takes readings at hourly intervals, is it reporting the beginning or the end of the hour?
Re: DNS
20-05-2013 6:01 PM
Quote from: townman @Matt,
Does support know why itswas broken?
Given that this has been seen before, does support know how to prevent it happening again?
Cheers,
Kevin
Re: DNS
21-05-2013 10:21 AM
