DNS problems
- DNS problems
DNS problems
14-12-2011 9:24 PM
Tonight my wife's work laptop will not connect to the internet via my home wifi. It is seeing and connecting to the wifi, but having DNS problems which means it can't connect to the internet. It used to work, and while I haven't changed anything at home her work have recently done a load of changes.
All my devices are working.
I need some little baby steps to sort this out. Anyone?
P.S. This is not AFAIK anything to do with Plusnet.
Re: DNS problems
14-12-2011 9:31 PM
Type 'ipconfig /all' (minus quotes) and press enter. What happens? Are you able to paste the results here?
Using the same command window, can you traceroute to an IP address using 'tracert 212.159.6.10' (minus quotes)?
Re: DNS problems
14-12-2011 9:48 PM
So retyping...
Tracing route to 212.159.6.10 over a maximum of 30 hops
1 1ms 1ms 1ms 192.168.0.254 (my router)
2 * * * Request timed out.
3 * * * Request timed out.
4 * * * Request timed out.
5 18ms 22ms 24ms 212.159.6.10
Trace complete.
Will try to copy the ipconfig stuff via a USB stick...
Re: DNS problems
14-12-2011 9:53 PM
Quote from: AxeMurderer Can't easily cut-and-paste...
Right-click the command window, left-click 'Mark', highlight the text you want to copy as usual, right-click it once (should copy it to your clipboard), then come here and paste it as you normally would.
Re: DNS problems
14-12-2011 9:55 PM
Re: DNS problems
14-12-2011 10:01 PM
>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : VIM000587a
Primary Dns Suffix . . . . . . . : lan.venture.co.uk
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : lan.venture.co.uk
home.gateway
Wireless LAN adapter Wireless Network Connection 2:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Microsoft Virtual WiFi Miniport Adapter
Physical Address. . . . . . . . . : 00-26-82-B5-8A-75
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . : home.gateway
Description . . . . . . . . . . . : Broadcom 4313 802.11b/g/n
Link-local IPv6 Address . . . . . : fe80::c4e6:392f:349e:743%14(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.6(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 14 December 2011 19:27:44
Lease Expires . . . . . . . . . . : 15 December 2011 21:41:12
Default Gateway . . . . . . . . . : 192.168.0.254
DHCP Server . . . . . . . . . . . : 192.168.0.254
DHCPv6 IAID . . . . . . . . . . . : 369108610
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-13-FB-17-57-1C-C1-DE-9D-EB-82
DNS Servers . . . . . . . . . . . : 2001:470:20::2
192.168.1.20
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : lan.venture.co.uk
Description . . . . . . . . . . . : Intel(R) 82577LC Gigabit Network Connecti
on
Physical Address. . . . . . . . . : 1C-C1-DE-9D-EB-82
Tunnel adapter isatap.{CD70993C-36D7-48DF-AF4F-DE8EAC4B56BB}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter isatap.home.gateway:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Tunnel adapter isatap.lan.venture.co.uk:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
Re: DNS problems
14-12-2011 10:25 PM
192.168.1.20
Seems odd that your primary server is an IPv6 address. You could try going to the wireless adapter properties via the Network applet of the control panel and make sure the properties for the IPv6 protocol stack are set to obtain an IP address/DNS servers automatically (if they're not already?)
Re: DNS problems
14-12-2011 10:41 PM
Her laptop is already set to obtain an IPv6 address automatically. But IPv6 could be something to do with it... I was/am an IPv6 triallist; I'm not using the IPv6 account at the moment, but I have left my router IPv6 enabled. This has been harmless to all my other devices but it is worth a try at disabling it.
Re: DNS problems
14-12-2011 10:54 PM
Re: DNS problems
14-12-2011 11:26 PM
Quote from: AxeMurderer Her laptop is already set to obtain an IPv6 address automatically. But IPv6 could be something to do with it... I was/am an IPv6 triallist; I'm not using the IPv6 account at the moment, but I have left my router IPv6 enabled.
Ah, that would explain it then, probs a red herring in which case. Come to think of it though the IPv4 address is odd, I'd expect it to be the router address (192.168.0.254) or one of our's/a third party's DNS server addresses.
Does it make any difference if you go into the IPv4 properties and explicitly set the DNS to the following?
212.159.6.10
8.8.8.8
Do you have the same problems if the laptop's wired rather than relying on the wireless connection?
