DNS problems with Technicolor TG582n
- DNS problems with Technicolor TG582n
- « Previous
- 1
- 2
- Next »
Re: DNS problems with Technicolor TG582n
18-02-2016 2:32 PM
19-02-2016 12:25 PM
GPS
21-02-2016 7:59 PM
I have the same issue with TG582n DNS.latest firmware update . I was initially told that I could upgrade to a new contract where I would get a better router or if not, I could buy one for £99 as my router was out of warranty ? Now the router worked fine until the new firmware was pushed out by plusnet
Spoke to another adviser who checked things and said make sure your router is kept on and its should resolve itself in a few day. Still here with websites dropping out on my pc and wireless laptop . No response to my reply on my issue.
21-02-2016 8:25 PM
today I found that there are even more customers likely to be affected than has been suggested: Users of Windows XP Vista and W 7 can also be affected.
I would think that PN are overwhelmed by the problem and unlikely to know what to do! My thinking is that they have been very let down by manufacturer Thompson, and are struggling to give meanigful advice to users.
The "fix" does work . You either need to request it is pushed to your router via this forum , or use telnet and do it yourself ! It's actually not that difficult and there is no need to actually unserstand what you're doing as the intructions are clear;
On a windows PC type Run in the start box
In the dos wndow that opens type :telnet 192.168.1.254
user name is "admin"
password is " router serial number" as shown on the label on base of router
type : dns server config WANDownSpoofing = disabled
then : saveall
then : exit
That's it!
Good luck
21-02-2016 8:32 PM
But quite annoyed by the initial response and the lack of response to my problem
Thanks for your response gpsmout
21-02-2016 9:13 PM
21-02-2016 10:01 PM
Quote from: rsinbad Well looks straight forward I think ?
The problem with this issue is that it is difficult to profile. I spent a year on and off identifying what is going on here. It is only quite recently that the symptoms have been clearly identified - an interaction of behaviours between some OS environments and this router. Bob is aware of the issue due to direct contact with him. Out of that a technical solution is being explored. Whilst the above configuration change seems to avoid the issue, the full implications of the change are not fully defined.
See - https://community.plus.net/forum/index.php/topic,134916.0.html
21-02-2016 11:09 PM
I turned off DNS spoofing on my TG582n based on Matt's advise. The "the full implications of the change" were that the problem was resolved as no spoofed addresses were subsequently encountered.
Quote from: gpsmout today I found that there are even more customers likely to be affected than has been suggested: Users of Windows XP Vista and W 7 can also be affected.
Quite correct gpsmount. There's even been an Ubuntu user encountered the issue. The only difference between Win8/10 and other OSes is the way you actually encounter the problem for want of better words.
@rsinbad
Have you got Telnet activated on your OS? You need it to be activated so that when you type Telnet 192.168.1.254 at the cmd prompt, you then get prompted for the TG582n username and then password.
21-02-2016 11:22 PM
1) this is best applied to the router over a wired Ethernet connection rather than wireless
2) ensure telnet is enabled on your computer
then type carefully only the text as follows inside parentheses (") also ensuring you leave the correct spaces between instructions
at the cmd prompt
type "run"
type "telnet 192.168.1.254"
you will be prompted for username
Type "admin"
you will be prompted for a password
Type the password which is " the routers serial number" as shown on the label on base of router and it is case sensitive ie soething like "CP1234ABCDE"
type : "dns server config WANDownSpoofing = disabled"
type : "saveall"
type : "exit"
21-02-2016 11:28 PM
You usually click on "Run" and then type cmd in the box, to get the command prompt. Then the telnet command.
All that typing should be without the " quote marks to be clear btw
I did recommend here that the cache be flushed before exit
dns server debug spoof clear
dns server debug spoof list
exit
The list command is just to check the cache is clear.
22-02-2016 7:32 AM
Thanks for your patience
22-02-2016 8:22 AM
Thanks all for your feedback .
I must say I'm somewhat disappointed with plusnet's lack of support
22-02-2016 12:48 PM
22-02-2016 1:16 PM
Log into the 582n GUI, depending on your screen after log in select >Advanced Options at the bottom of the screen if need be, then
On the LH menu, select >Technicolor Gateway then >Configuration then >Save or Restore Configuration from the bottom of the page.
On the Backup& Restore screen, click >Backup Configuration Now. You'll be prompted with a default filename of user.ini which you can change if you wish, when prompted for the Folder to save it in.
Once saved (it's a text file), open it with a basic text reader (eg. Notepad or similar) and search for WANDown. You should find it in the [ dnss.ini ] section where it should say WANDownSpoofing=disabled
HTH.
22-02-2016 9:26 PM
Thanks Anotherone
I have made a backup and WANDownSpoofing is disabled . So far the fix seems to have worked .
- « Previous
- 1
- 2
- Next »
