DNS problems again?
DNS problems again?
I'm having issues with sites atm either very slow loading or not at all.
http://forums.anarchy-online.com/ is the main culprit atm
If i run a trace im finding I get blocked on hop one when its really bad and then it slowly clears up and the trace completes.
I'm currently on
pcl-ag02
using
212.159.13.49
212.159.13.50
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Fixes: 21
Re: DNS problems again?
I'm suspecting something more to do with the traffic shaping up the creek.
James
We did have a problem yesterday where rate limits weren't being applied correctly on one central on the unlimited product.
This may have had an impact on http speeds, but it shouldn't have done as this pipe was being under used as it had already experienced a drop (hence why the rate limits weren't being applied).
Is this still ongoing for you?
Yep still on going and seeing the other thread on it as well from this morning I've now given up on your DNS servers for Opendns, now no problems.
208.67.220.220
208.67.222.222
Wheel_nut
Is there an outlook for a fix on this issue? DNS resolution is very iffy and has been since the weekend.
James
@WN
The problem was fixed yesterday and we haven't seen any complaints since.
@ james more today but not dns this time but the other problem re-surfaced, just had all traffic blocked for last 5mins no idea which gateway I was on but rebooted my router and now on ptn-ag2 which its self seems to be running slow
I'm still having intermittent page timeout problems (last night and this morning)
Bob
Fixes: 86
Quote from: bobboulby
Not convinced that's going to be DNS TBH. I've not noticed any problems here and our monitoring systems suggest that all is healthy.
No problems so far this morning.
Bob
