DNS issues - BTWholeSale
andreas1999
I can't connect to the internet using the standard plus.net settings. I've changed to use Google's DNS servers which fixes the problem, but it's frustrating to have to do this on all my machines. Am I the only one experiencing this? I've had this problem before with plus net but I can't remember what the fix was for it.
Maybe someone can help me?
Fixes: 25
Re: DNS issues - BTWholeSale
Can you change the DNS setting on your router so you don't have to do it on all your machines?
andreas1999
Quote from: ReedRichards
That's what we ended up doing. But why does this keeps happening with Plusnet?
Estragon
Are you setting the DNS values manually, instead of just letting the router get them from Plusnet on connection? If so, are they still the correct ones, and what happens if you let it just pick them up automatically?
flaminmoses
oddly my new linksys wont allow me to set my own dns values
