DNS help TG582n
Fixes: 4
DNS help TG582n
These commands don't seem to work on the TG582n FTTC, am i missing something or do these commands not work with this firmware/router ?
dhcp client ifdetach intf=Internet
dhcp client rqoptions delete intf=Internet option=domain-name-servers
dhcp client ifattach intf=Internet
Fixes: 6
Re: DNS help TG582n
The default setting in my tg582n FTTC, show the interface "Internet" has not been added or attached to the dhcp client. So the rqoptions is already disabled.
Test this yourself with:
dhcp client iflist
Fixes: 4
Re: DNS help TG582n
Here is the output.
   /         /\\  8.C.M.0.DG
                  _____/__      /  \\
                _/      /\_____/___ \  Copyright (c) 1999-2012, Technicolor
      _______//_______/    \    / _\/______
  __/      /  \      \  /    / /        / _\__
  / /      /    \_______\/    / /        / /  /\
/_/______/___________________/ /________/ /___/  \
\ \      \    ___________    \ \        \ \  \  /
  \_\      \  /          /\    \ \        \ \___\/
      \_____/          /    \    \ \________\/
          /__________/      \    \  /
          \  _____  \      /_____\/
            \ /    /\  \    /___\/
            /____/  \  \  /
            \    \  /___\/
              \____\/
{admin}=>dhcp client iflist
{admin}=>
I was under the impression that the DNS stayed static after changing to opendns ip's  "3) Set the router to use opendns as the only dns resolver." but when the ppp connection is dropped i get fresh dns ip's added from plusnet again, i'm confused.
{admin}=>:dns server route list
DNS Server Entries:
DNS Server    Source                Label              Metric Intf        State  Domain
S 208.67.222.123                                          1      Internet      UP      *
S 208.67.220.123                                          2      Internet      UP      *
S 212.159.6.9                                                10    internet      UP      *
S 212.159.6.10                                              10    internet      UP      *
{admin}=>
Fixes: 6
Re: DNS help TG582n
That method worked for a O2 connection but not here.
Try method 2) here to configure the DNS:
http://npr.me.uk/changedns.html
Fixes: 4
Re: DNS help TG582n
@npr Thanks for the help, but it appears that this option will not work for a static setup. I have also been doing some testing again today trying to use the router ip for resolving but i'm still getting errors, i give up with it all i really do Sad
Fixes: 6
Re: DNS help TG582n
If you must use static IP's on the LAN then you can go back to the first method. The PN dns will not be used unless both opendns resolvers actually stop responding.
The fact that the opendns metric is 1 and 2 means they will always be used before the PN dns with a metric 10.
apjashley1
Re: DNS help TG582n
Have you got OpenDNS's IP addresses right? Yours seem to end .123
Fixes: 6
Re: DNS help TG582n
