DNS error
- Re: DNS error
DNS error
05-06-2013 11:43 AM
I use Google Chrome on Windows Vista and have been getting the following error intermittently but regularly (daily): Error 105 (net::ERR_NAME_NOT_RESOLVED): Unable to resolve the server's DNS address.
This is happening with popular websites such as Google and Facebook and will last for around 10-15mins before seeming to rectify itself. I have a feeling it may be down to my router which I've not been happy with since day 1. WIFI is flaky and unreliable and often stops working altogether with only a reset of the router curing that issue. The router is a Netgear N150. I've ordered a new router which should resolve the WIFI issue and I'm hoping will also resolve the DNS error issue. But is there anything else I should be looking at with regard the DNS errors?
Message 1 of 5
(945 Views)
4 REPLIES 4
Re: DNS error
05-06-2013 11:56 AM
Hi MJC and welcome to the forums. I had the same thing you describe with my TG582n Router, if you know how to, you can specify just the dns servers on 1 of your machines just to see if the resolver in you router keeps falling over etc.
212.159.6.9
212.159.6.10
Put those in just 1 machine and see how you go, then you can work on resolving the problem with the guys on here
Good luck.
212.159.6.9
212.159.6.10
Good luck.
Message 2 of 5
(502 Views)
Re: DNS error
05-06-2013 12:04 PM
This may help http://support.zen.co.uk/kb/Knowledgebase/Windows-7-Static-DNS-setup.
As i said this is just to try it out for a few days, just tick the top option in the dns part to put everything back to normal.
Message 3 of 5
(502 Views)
Re: DNS error
06-06-2013 9:31 AM
Message 4 of 5
(502 Views)
Re: DNS error
06-06-2013 2:15 PM
Thanks for the replies chaps, I will give that a go.
Message 5 of 5
(502 Views)
