DNS and Samsung smart 3D TV problem
- DNS and Samsung smart 3D TV problem
26-05-2014 8:51 PM
This was until today, I selected I-Player and told my the connection had interference. I checked it out and it told me there was a connection to the router but not to the internet.
All other devices such as telephones, iPad and pcs are working fine.. But not the tv. I tried 8.8.8.8 google dns and the tv connect straight away..
So the question is why will my tv not connect when the dns setting is auto, it has been in this setting for two years...
David
Re: DNS and Samsung smart 3D TV problem
26-05-2014 9:05 PM
26-05-2014 9:15 PM
26-05-2014 9:33 PM
26-05-2014 9:35 PM
Anyone know whats going on ? tried manually entering dns settings and says connected in network settings ...but when go to smart hub or an app it says not connected to net ...when go back to network settings it says not connected to internet ...weird
Any help most appreciated
p.s everything else connects to net ...laptops , phones , xbox one etc
26-05-2014 9:37 PM
David
26-05-2014 9:52 PM
[tt]
Nameserver Response Time (ms)
min/avg/max/stdev/retries
4.2.2.1 17.79/19.00/20.26/0.87/0
4.2.2.6 17.77/18.31/19.08/0.48/0
208.67.222.123 17.79/18.33/18.82/0.34/0
208.67.220.123 18.01/18.33/18.66/0.22/0
208.67.222.222 17.95/18.43/18.68/0.28/0
208.67.220.222 18.26/18.93/20.10/0.74/0
212.159.6.9 18.82/19.49/20.14/0.46/0
212.159.6.10 18.47/18.65/19.07/0.25/1
212.159.13.49 18.88/19.37/19.95/0.43/1
212.159.13.50 18.49/18.84/19.77/0.48/0
8.8.8.8 17.91/20.87/25.49/3.43/0
8.8.4.4 17.97/22.49/25.98/3.57/0[/tt]
26-05-2014 10:07 PM
Quote from: stealth Have you tried googles dns 8.8.8.8 ?
David
Hi David
So where do you put those settings ? in the smart player or router ?
any help most appreciated
Karl
p.s connected wirelessly to a bt homehub 5 ...used as router only
26-05-2014 10:11 PM
If you put it in the smart device, only that device will use the IP for the DNS server.
26-05-2014 10:20 PM
Changed to use google DNS and all OK
Maybe some apps are very sensitive to DNS issues?
26-05-2014 10:43 PM
Quote from: DomS If you put them in the router, all devices will be assigned that IP for the DNS server.
put it into my smart player ....now works a treat
thank you
karl
26-05-2014 10:44 PM
Quote from: timcropley
TV's probably don't have a dns cache, also CDN servers tend to have a short ttl time making them more sensitive to flakey name servers.
The following link is a script to change the TG582n routers DNS settings to opendns.
http://npr.me.uk/dns-script.zip
The script can easily be modified to google dns.
Suitable for R8 and R10 firmware.
27-05-2014 9:45 AM
I would get your graph looked at. The packet loss is not right and not normal - it will affect pretty much anything you do.
27-05-2014 11:06 AM
27-05-2014 11:11 AM
What is the current status of that issue please? Non-responsiveness of PN DNS servers is a reoccurring issue as I have noted elsewhere and offered help on profiling when I see it.
Kevin
