DNS Server
danielmclean
DNS Server
anyone else having DNS Server related  problems ?
using
Primary DNS Server         212.159.13.49
Secondary DNS Server 212.159.13.50
Re: DNS Server
What sort of problems?
racquel
Re: DNS Server
I'm not sure if it's DNS related, but I'm having problems getting to several websites via plusnet. If I use an "is it up" service or a VPN, it's fine.
Can't see anyone else complaining on twitter, so I'm wondering if it's just affecting a few users.
Fixes: 20
Re: DNS Server
danielmclean
Re: DNS Server
i normally get this        dns_probe_finished_no_internet    on google.co.uk     facebook.com   and nearly all other sites  no matter what device i use and normally last   10 - 15 minutes
Fixes: 162
Re: DNS Server
It shouldn't make a difference, but do you get the same issues if you allow DNS to be automatically assigned rather than setting the addresses manually?
 Chris Parr
 Plusnet Staff
danielmclean
Re: DNS Server
no
Fixes: 162
Re: DNS Server
That suggests that leaving them automatically assigned is the best bet for you.
 Chris Parr
 Plusnet Staff
danielmclean
Re: DNS Server
does plusnet support IPv6  yet?
