DNS Routing Failure
- DNS Routing Failure
DNS Routing Failure
09-08-2009 11:21 PM
I've been having problems resolving web names and it looks as thought the problem is because the automatic resolution of the DNS is to 212.159.6.9 then 212.159.6.10. When I have this default setup I cannot browse the web (connecting directly to IP works fine, so games and such seem ok), however if I switch them around it works fine.
Is there a problem with 212.159.6.9 that needs resolved?
Cheers,
Yarek
Re: DNS Routing Failure
10-08-2009 10:09 AM
If one source goes down the other is available as a backup.
10-08-2009 10:26 AM
10-08-2009 10:34 AM
Quote from: ReedRichards The idea of using one Plusnet DNS address and one OpenDNS address does not say much for the reliability of the Plusnet DNS servers.
...or, as one could extrapolate, OpenDNS servers. I think the idea was to put as much 'distance' between the two options as possible.
It was just a thought though
10-08-2009 10:36 AM
10-08-2009 12:49 PM
Quote from: Yarek Is there a problem with 212.159.6.9 that needs resolved?
Not as far as I'm aware. TBH, the IP address you use does not determine the site that your DNS requests will be routed to. They'll always be routed to the closest site to the edge router you're connected to (although there are multiple servers at each site).
If you have the problem again then open a command prompt and perform a lookup against each of the caching server addresses you're using.
C:\Users\Bobby>nslookup bbc.co.uk 212.159.6.9
Server: ptn-cdns01.plus.net
Address: 212.159.6.9
Non-authoritative answer:
Address: 212.58.224.138
C:\Users\Bobby>nslookup bbc.co.uk 212.159.6.10
Server: ptn-cdns02.plus.net
Address: 212.159.6.10
If you get a result like the one above then that suggests that DNS resolution is working as it should be.
There's certainly no harm in adopting a bit of redundancy. It's also useful if you use your machine for roaming because you'll not be able to connect to the Plusnet caches from a non-Plusnet connection.
13-08-2009 10:30 AM
Quote from: Bob Not as far as I'm aware. TBH, the IP address you use does not determine the site that your DNS requests will be routed to. They'll always be routed to the closest site to the edge router you're connected to (although there are multiple servers at each site).
Bob - are you saying in effect that it is a waste of time entering DNS, whether they be PN or OpenDNS, as they won't be used anyway?
13-08-2009 11:39 AM
So, PN when you see the 212.159.6.9 and 212.159.6.10 addresses, this is not two servers, but two load balancers, which each share the load amongst multiple servers.
13-08-2009 12:59 PM
Or have I totally misunderstood the answer
13-08-2009 6:47 PM
13-08-2009 6:51 PM
13-08-2009 6:54 PM
adie:quote
13-08-2009 7:30 PM
Quote from: Oldjim
If you have then so have I as it read it in exactly the same way.
13-08-2009 7:38 PM
18-08-2009 7:27 PM
Today, it's completely borked and I';m not able to browse at all (can connect to direct IP addresses again though) and my work PC using work DNS is working (that's what I'm using to type this btw!).
When I try the above nslookup bbc.co.uk <dns IP> it completely fails (times out) with 212.158.6.10 but resolves as above with 212.158.6.9 (isn't this the other way around from before? oh well).
I'll try the opendns as a temporary measure and see if that resolves my problem in the meantime. Please try and fix the issues as there's clearly something not working with the DNS currently.
