DNS Patch
- DNS Patch
DNS Patch
22-08-2008 8:25 AM
Hi
I am not sure whether this is the right place to ask the question but I was reading an article yesterday on the guardian online (http://www.guardian.co.uk/technology/2008/aug/21/hacking.internet) where they were discussing the recent DNS security flaw.
The article recommended checking with our ISP whether they had patched their DNS servers. Alternatively they pointed out that opendns.com have already patched their servers and looking that site up, they have some very easy to use instructions on how to configure my Belkin router to bypass PlusNet DNS servers.
My questions: Has PlusNet patched their servers? Is it safe enough for me to change my router's default DNS servers to the open DNS ones (assuming PlusNet, has not patched their servers yet)?
Any help will be appreciated.
Michael
Michael
Message 1 of 5
(1,227 Views)
4 REPLIES 4
Re: DNS Patch
22-08-2008 8:34 AM
Plusnet were one of the first ISP's to have installed the patch on all their DNS servers.
You can check the status on Dan's website at: http://www.doxpara.com/ ; (click the Check my DNS button)
B.
B.
Message 2 of 5
(474 Views)
Re: DNS Patch
22-08-2008 10:08 AM
Thanks Barry
Certainly good to know as I was not too keen to start fooling around with router settings.
Will check on that link for piece of mind later tonight when I get home.
Michael
Michael
Message 3 of 5
(474 Views)
Re: DNS Patch
22-08-2008 4:02 PM
You might find the Community site blog DNS Flaw Revealed published on 24/07/2008 adds to your reassurance.
David
David
David
Message 4 of 5
(474 Views)
Re: DNS Patch
22-08-2008 10:53 PM
You must remember that the dns the router has has no effect on your pc unless you pc is configured to use the router as dns. You need to check what dns your pc is using with the old ipconfig /all from a cmd prompt
Message 5 of 5
(474 Views)
