DNS Issues
derkane
DNS Issues
Hi Guys,
I am trying to reach a domain www.daffi.co.uk
It works on my mobile and at work, however not at home, I get this tracert.
Tracing route to daffi.co.uk [85.92.75.157]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  10.0.0.1
  2    50 ms  100 ms    99 ms  192.168.1.254
  3    34 ms    42 ms    34 ms  lo0-central4.ptn-ag03.plus.net [195.166.130.79]
  4    34 ms    35 ms    35 ms  gi2-24-342.ptn-gw02.plus.net [84.93.253.51]
  5    34 ms    34 ms    34 ms  xe-0-0-3.border-1.thn.lon.uk.as29017.net [195.66
.226.141]
  6    *      34 ms    35 ms  xe-0-0-1.core-1.centro.hml.uk.as29017.net [89.14
5.125.34]
  7    36 ms    38 ms    35 ms  rt01b.cr-1.lon.as34282.net [89.145.72.178]
  8    *        *        *    Request timed out.
Cheers,
Oli
Fixes: 4
Re: DNS Issues
Your link works for me !
$ mtr -r -c 100 www.daffi.co.uk
HOST: my_pc                      Loss%  Snt  Last  Avg  Best  Wrst StDev
  1. my_gateway                    0.0%  100    3.1  4.3  3.1  8.2  1.1
  2. lo0-homesurf.pcl-ag06.plus.n  0.0%  100  17.3  18.0  15.7  23.9  1.8
  3. gi7-6-755.pcl-gw01.plus.net  1.0%  100  28.4  32.6  24.1 211.6  27.3
  4. te2-2.pte-gw1.plus.net        0.0%  100  26.9  30.3  24.2 198.9  20.2
  5. po4.pte-gw2.plus.net          0.0%  100  26.0  29.2  24.4 105.8  12.1
  6. xe-0-0-3.border-1.sov.lon.uk  0.0%  100  28.1  26.7  24.2  45.2  3.0
  7. xe-0-0-1.core-2.centro.hml.u 12.0%  100  26.6  30.2  24.9 183.8  17.7
  8. rt01a.cr-1.lon.as34282.net    0.0%  100  26.0  27.9  25.3  38.0  2.0
  9. uk7.myserverhosts.com        0.0%  100  27.1  27.1  25.4  31.9  1.3
$ traceroute www.daffi.co.uk
traceroute to www.daffi.co.uk (85.92.75.157), 30 hops max, 60 byte packets
1  my_gateway (192.168.xxx.xxx)  5.627 ms  6.396 ms  6.384 ms
2  lo0-homesurf.pcl-ag06.plus.net (195.166.130.42)  19.129 ms  21.507 ms *
3  * * *
4  * * *
5  * * *
6  * * *
7  * * *
8  rt01a.cr-1.lon.as34282.net (89.145.72.182)  31.113 ms  31.089 ms  31.066 ms
9  uk7.myserverhosts.com (85.92.75.157)  31.075 ms  31.068 ms *
Fixes: 62
Re: DNS Issues
and me as shown below but a tracert of www.daffi.co.uk/ comes up with unable to resolve target system name
C:\Users\Jim>tracert www.daffi.co.uk/
Unable to resolve target system name www.daffi.co.uk/.
C:\Users\Jim>tracert daffi.co.uk
  1    1 ms    <1 ms    <1 ms  192.168.0.1
  2    37 ms    35 ms    41 ms  lo0-central1.pcl-ag02.plus.net [195.166.128.235]
  3    36 ms    35 ms    34 ms  gi1-13-211.pcl-gw01.plus.net [84.92.6.32]
  4    35 ms    35 ms    36 ms  te2-2.pte-gw1.plus.net [212.159.0.186]
  5    36 ms    35 ms    35 ms  po4.pte-gw2.plus.net [212.159.1.188]
  6    35 ms    35 ms    37 ms  xe-0-0-3.border-1.sov.lon.uk.as29017.net [195.66
.224.141]
  7    37 ms    36 ms    36 ms  xe-0-0-1.core-2.centro.hml.uk.as29017.net [89.14
5.125.38]
  8    37 ms    36 ms    36 ms  rt01a.cr-1.lon.as34282.net [89.145.72.182]
  9    36 ms    36 ms    35 ms  uk7.myserverhosts.com [85.92.75.157]
Trace complete.
and I get to the website OK but this is the actual address http://daffi.co.uk/
derkane
Re: DNS Issues
Mine is timing out for some reason...
Even ping cannot reach it:
Pinging daffi.co.uk [85.92.75.157] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 85.92.75.157:
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
derkane
Re: DNS Issues
Its set to auto resolve www.daffi.co.uk to daffi.co.uk
Fixes: 4
Re: DNS Issues
$ ping daffi.co.uk
PING daffi.co.uk (85.92.75.157) 56(84) bytes of data.
64 bytes from uk7.myserverhosts.com (85.92.75.157): icmp_req=1 ttl=56 time=26.5 ms
64 bytes from uk7.myserverhosts.com (85.92.75.157): icmp_req=2 ttl=56 time=24.8 ms
64 bytes from uk7.myserverhosts.com (85.92.75.157): icmp_req=3 ttl=56 time=26.9 ms
64 bytes from uk7.myserverhosts.com (85.92.75.157): icmp_req=4 ttl=56 time=23.3 ms
64 bytes from uk7.myserverhosts.com (85.92.75.157): icmp_req=5 ttl=56 time=26.4 ms
$ ping www.daffi.co.uk
64 bytes from uk7.myserverhosts.com (85.92.75.157): icmp_req=1 ttl=56 time=28.0 ms
64 bytes from uk7.myserverhosts.com (85.92.75.157): icmp_req=2 ttl=56 time=28.4 ms
64 bytes from uk7.myserverhosts.com (85.92.75.157): icmp_req=3 ttl=56 time=27.9 ms
64 bytes from uk7.myserverhosts.com (85.92.75.157): icmp_req=4 ttl=56 time=26.3 ms
64 bytes from uk7.myserverhosts.com (85.92.75.157): icmp_req=5 ttl=56 time=27.6 ms
derkane
Re: DNS Issues
Moved my DNS settings from Plusnet to OpenDNS and it works again.
