DNS Issues?
grahamn
DNS Issues?
Hi, I was just wondering if anyone was experiencing DNS related issues today - specifically with Lloyd's Bank?
Friends not on Plusnet can access it, can also do so over 4G but cannot do so over any of my broadband connected systems.
Their website returns the following message:
This site can’t be reached
www.lloydsbank.com’s server DNS address could not be found.
  • Try running Windows Network Diagnostics.
DNS_PROBE_FINISHED_NXDOMAIN"
Thanks.
Fixes: 192
Re: DNS Issues?
No problem accessing Lloyd's bank from here but I use Google's DNS: 8.8.8.8 & 8.8.4.4
Forum Moderator and Customer
grahamn
Re: DNS Issues?
Many thanks - yes tried googles too, but still a problem.
Eventually I decided to restore my router from a prev config save and it started working again with the lloyds website - odd that only the llloyd's site seems to be an issue though...will probably never know why.
Fixes: 81
Re: DNS Issues?
www.Lloydsbank.com failed for me but https://www.lloydsbank.com/ works.
Customer and Forum Moderator.
Fixes: 192
Re: DNS Issues?
Both worked for me although the former took a much longer time to display.
Creasey-Coombs
Re: DNS Issues?
I'm also having issues with a DNS error on https://www.lloydsbank.com/. Is there a proper fix from Plusnet for this? I've only been with them for just over a day and this isn't a good start.
