DNS Issues Technicolor TG582n
NivagSwerdna
Out of the blue I have lost connectivity from all the devices on my LAN
It appears that DNS names are not resolving.
Currently all the LAN devices use DHCP to return a DNS Server address of 192.168.1.1 (the router)
The router then acts as a DNS relay to
Primary DNS: 212.159.6.9
Secondary DNS: 212.159.6.10
However DNS names are not resolving anymore.
If I change a PC to have 192.168.1.1 & 212.159.6.10 it does seem to (at least sometimes) resolve DNS
What has changed to break the DNS relay function of my PlusNet supplied router???
Thanks in advance
Nivag
22 REPLIES 22
NivagSwerdna
Re: DNS Issues Technicolor TG582n
nslookup www.yahoo.com 192.168.1.1
Server:  UnKnown
Address:  192.168.1.1
DNS request timed out.
    timeout was 2 seconds.
*** Request to UnKnown timed-out
Very odd.
nslookup www.yahoo.com 212.159.6.10
Server:  cdns02.plus.net
Address:  212.159.6.10
Non-authoritative answer:
Addresses:  2a00:1288:f006:1fe::3000
          2a00:1288:f00e:1fe::3001
          2a00:1288:f006:1fe::3001
          2a00:1288:f00e:1fe::3000
          46.228.47.115
          46.228.47.114
Aliases:  www.yahoo.com
          fd-fp3.wg1.b.yahoo.com
          ds-fp3.wg1.b.yahoo.com
          ds-eu-fp3-lfb.wa1.b.yahoo.com
Router looks fine...
Connection Information
Uptime: 0 days, 0:49:46
Data Transferred (Sent/Received) [MB/GB]: 187.75 / 7.66
Username: XXXXXX@plusdsl.net
Password: ********
Remember Password: Yes
IP Address: AAA.BBB.CCC.DDD
Looks OK
Just DNS via 192.168.1.1 that is broken
NivagSwerdna
Interesting... appears intermittent....
Server:  UnKnown
Addresses:  2a00:1288:f006:1fe::3001
          46.228.47.114
          46.228.47.115
Are there system wide DNS issues at present???
ejs
Aspiring Hero
Fixes: 25
A handful of people have previously reported problems with the DNS forwarding server in the router:
https://community.plus.net/forum/index.php/topic,122856.msg1083269.html#msg1083269
https://community.plus.net/forum/index.php/topic,116178.0.html
I don't think anyone knows the exact cause of the problem or if 212.159.6.9 being slow to respond, or packets being lost to the way to/from 212.159.6.9 might have anything to do with the problem.
It is possible to configure the router's DHCP server to assign different DNS server addresses to devices on your network: http://npr.me.uk/changedns.html "Method 2" to workaround the problem.
30FTTC06
Fixes: 4
A quick look at DNS-Servers in general for today. Everything appears to be in order.
The dozen or so popular servers i've tested below seem fine today, the test below sends 10 requests to google.com and uses 5 of those requests to give the results you see below for each server.
[tt]Nameserver          Response Time (ms)
                    min/avg/max/stdev/retries
192.168.0.15        0.55/0.56/0.56/0.00/0
192.168.0.254      19.41/19.88/20.27/0.29/0
212.159.6.9        19.32/19.51/19.60/0.10/0
212.159.6.10        18.57/19.51/20.79/0.86/0
212.159.13.49      18.51/19.34/20.24/0.62/0
212.159.13.50      18.35/19.22/19.98/0.68/0
208.67.222.222      17.98/18.27/18.43/0.17/0
208.67.222.220      17.96/18.41/18.78/0.26/0
208.67.222.123      18.19/18.37/18.66/0.17/0
208.67.220.123      17.94/18.27/18.69/0.26/0
8.8.8.8            23.23/24.04/25.18/0.69/0
8.8.4.4            17.53/17.89/18.28/0.31/0
4.2.2.1            17.68/18.17/18.73/0.44/0
4.2.2.6            17.69/18.23/18.58/0.30/0
The following name servers are used for lookup of google.co.uk.
forwarding request:
Delegation with 0 names, of which 0 can be examined to query further addresses.
It provides 2 IP addresses.
208.67.222.123  rto 53 msec, ttl 116, ping 25 var 7 rtt 53, tA 0, tAAAA 0, tother 0, EDNS 0 probed.
208.67.220.123  rto 44 msec, ttl 192, ping 24 var 5 rtt 50, tA 0, tAAAA 0, tother 0, EDNS 0 probed.[/tt]
The test above is just giving me a gerneral thumbs up that all is well with my normal Opendns servers that i use via my cache.
And the 2 tests below are samples taken in the last hour, they also test the 20 or so dns-servers with about 200 global requests each.
As you can see Level3 has a few requests failing, but nothing major in all honesty.
ejs has pointed out that a few people have had problems with the TG582N forwarder, but nothing conclusive has been proved. One way of solving your problem NivagSwerdna is by disabling the forwarder as ejs has pointed out, although that option does work, it doesn't work for me because i need to force the route for dns traffic through the forwarder. IE  for Opendns.
NivagSwerdna
I really want to keep the DNS relay function in the Technicolor as I also have a habit of adding my own static entries and would like to continue to not have to define my own bind/DNS service...
Anyway...
Got home today to loads of grumbles from the family... nothing accessible again... DNS resolution down again...
Once again....
Server:  UnKnown
but
nslookup www.yahoo.com 212.159.6.9
Server:  cdns01.plus.net
Address:  212.159.6.9
Addresses:  2a00:1288:f00e:1fe::3000
          46.228.47.115
          46.228.47.114
Clearly the DNS relay in the technicolor (stock Plusnet router) stuffed again.
Decided to have a closer look...
{admin}[dns server route]=>list
DNS Server Entries:
  DNS Server    Source                Label              Metric Intf        State  Domain
D 212.159.6.9                                            10    Internet      UP      *
D 212.159.6.10                                            10    Internet      UP      *
Not sure what the "D" on the front of the line means but it doesn't look healthy
{admin}[dns server route]=>flush
{admin}[dns server route]=>add dns=212.159.6.10 metric=0 intf=Internet
{admin}[dns server route]=>add dns=212.159.6.9 metric=0 intf=Internet
DNS Server Entries:
S 212.159.6.10                                            0      Internet      UP      *
S 212.159.6.9                                            0      Internet      UP      *
And then back to the PC...
Server:  UnKnown
          46.228.47.114
          46.228.47.115
          77.238.160.51
Working again for now.  I don't imagine I'm the only person suffering this.  What has changed?
npr
Fixes: 9
What result do you get from the following cli command?
dhcp server pool list name=LAN_private
NivagSwerdna
Go and have a bath.... listening to BBC Radio Player, HHGTG Fit The First, in the bath....  Smiley
20 mins in... silence...
Come down stairs to find....
Server:  UnKnown
DNS Server Entries:
So router appears normal... And has not dropped (Uptime: 0 days, 3:58:59)
Did
DNS Server Entries:
And temporarily working again.  Something causing the Technicolor Router DNS to go deaf.
There are some disconcerting things in the logs....
Mar 14 20:30:18 IDS scan parser : tcp port scan: 173.194.41.161 scanned at least 10 ports at A.B.C.D. (1 of 1) : 173.194.41.161 A.B.C.D 0040 TCP 443->55150 [...R..] seq 1069446595 win 0
and lots of...
Mar 14 18:16:14 FIREWALL replay check (1 of 1): Protocol: ICMP Src ip: 178.44.133.228 Dst ip:  A.B.C.D Type: Destination Unreachable Code: Port Unreacheable
NivagSwerdna
{admin}=>dhcp server pool list name=LAN_private
Pool              Address Range        Intf      Admin  Alloc  State
0  LAN_private    192.168.1.[201-252]  LocalNetwork up    dynamic static
DHCP server  = 192.168.1.1
Netmask      = 255.255.255.0
Leasetime    = 86400s
Lockouttime  = 180s
Gateway      = 192.168.1.1
DNS domain    = myDomain.com
DNS address list:
192.168.1.1 (local DNS)
{admin}=>
Looks fine
NivagSwerdna
This is interesting....
{admin}[dns server debug]=>stats
Corrupted packets received      :    30075
Local questions resolved        :        0
Local negative answers sent      :      312
Total DNS packets forwarded      :    32591
External answers received        :      4240
Spoofed responses                :      212
Forward table full, discard      :        98
Spurious answers                :      954
Unknown query types              :        0
I'll reset stats and see if these are current.
npr
Fixes: 9
Don't know if this is the cause of your problem but I'm not sure "myDomain.com" is a good idea.
Anything ending with a 1st level domain seems a bad idea to me.
Try reverting to "lan" or just "mydomain"
NivagSwerdna
Gone deaf again.  I wonder what a 'corrupted packet' is?  Some sort of DoS attack?
Corrupted packets received      :    10672
Local negative answers sent      :        6
Total DNS packets forwarded      :      9544
External answers received        :      1968
Spoofed responses                :        39
Forward table full, discard      :        11
Spurious answers                :        58
NivagSwerdna
Also the "dns server spoof list" seems to have many entries... no idea what that means!
NivagSwerdna
There seems to be nothing I can do to keep my DNS relay alive...
Corrupted packets received      :    46177
Local negative answers sent      :      104
Total DNS packets forwarded      :      4670
External answers received        :      6459
Spoofed responses                :        42
Forward table full, discard      :      989
Spurious answers                :      1385
So giving up on the Technicolor for a few days and just hardcoding 212.159.6.9 as DNS server
Something isn't right at all.... Maybe someone is spoofing DNS?
30FTTC06
Fixes: 4
{admin}=>:connection list proto=udp
{admin}=>:connection list ip=192.168.1.1
