DMT tool now works with Billion 7800N
Just spotted this for those who might be interested..
http://www.billion.uk.com/forum/viewtopic.php?f=9&t=306
Edit: works straight out of the tin, just enter the URL and login details.
Fixes: 135
Re: DMT tool now works with Billion 7800N
I'm very wary of downloading exe files from an unverifiable source.
Customer and Forum Moderator.
Scan the file with your antivirus first. It works fine, honest!  Wink
Fixes: 62
Yes Routerstats works too!
DMT is a bit more simple to set up, and I don't think some people could get Routerstats working.
And yes, DMT is different from Routerstats.  Cheesy
Fixes: 62
Post edited  Grin Grin
Fixes: 135
Yes I've had RouterStats working for a while now Smiley
Ok I'll give the DMT a run. I'll send you the repair bill if it all goes pear-shaped nozzer Wink Cheesy
Fixes: 135
Error: Cannot identify modemtype
Cry
@Strat, well lets put it this way, my PC has survived, and I've looked at the open ports on the machine and there's nothing untoward going on except the DMT accessing the router, so I think it will be fine.
Have faith my son!  Wink  (Famous last words).
Fixes: 135
RouterStats was running in the background preventing access for DMT and I'm man enough to admit it Embarrassed
Now it's running with no disasters Cool
Every one a winner!
